Raster layer - Howto?
Pascal Ehlert
dadark at DADARK.DE
Thu Nov 1 11:10:34 EDT 2007
Hi Brent!
Thank you so much for your effort, I definitely owe you a drink!
This is a really cool overview of world files and mapping stuff at all!
Greetings,
Pascal
Brent Fraser wrote:
> Pascal,
> I would guess the data is in a geographic coordinate
> system. This means the units of coordinates and pixel sizes
> for the image would be degrees not meters. I would also
> assume that the image covers the entire Earth, not just a
> part of it, so:
> Calculating the X (longitude) pixel size, 360 degrees covers
> the Earth all the way around:
> 360 degrees / 8192 pixels = 0.0439453125 degrees per pixel
> in X
> Calculating the Y (latitude) pixel size, 180 degrees covers
> the Earth pole to pole:
> 180 degrees / 4096 pixels = 0.0439453125 degrees per pixel
> in Y
> Notice the pixel size in X is the same as Y. This is
> typical for a raster map (but not a hard rule).
> And now for a reality check. Approximately how many
> meters-on-the-ground is each pixel?
> 0.0439453125 degrees/pixel * 60 minutes/degree * 60
> seconds/minute * 30 meters/second (approx) = 4700
> meters/pixel
> Interesting information, but not needed for the tfw file.
> So back to the calculations for the tfw file:
> The coordinates of the upper-left corner of the upper left
> pixel would be
> X = -180 degrees
> Y = 90 degrees
> But the tfw file specifies the MIDDLE of the upper left
> pixel (so we need to subtract half a pixel width from each
> coordinate):
> X = -180 + 0.0439453125/2 = -179.97802734375
> Y = 90 - 0.0439453125/2 = 89.97802734375
> So the tfw file would be:
> 0.0439453125
> 0
> 0
> -0.0439453125
> -179.97802734375
> 89.97802734375
> One more step for Mapserver:
> Since the tiff file is not a geotiff, you need to tell
> mapserver the coordinate system of the raster file. So your
> layer definition in the the map file would be (note the
> PROJECTION object):
> ########## NASA BLUE MARBLE ###########
> LAYER
> NAME "satellite"
> DATA "/var/www/odamap/blue_marble.tif"
> TYPE RASTER
> PROJECTION
> "geographic"
> END
> METADATA
> "wms_title" "ODAdata WMS Server SATELLITE"
> END
> END
