Using Demo in the Wiki Causes All My PHP/Mapscript Examples
to Die
Bill Thoen
bthoen at GISNET.COM
Fri Nov 2 16:09:37 EDT 2007
Going back through my notes on how I installed PHP and mapscript I
quoted you in my notes:
> "Well, by downloading and using the PHP source of the same version as
> what is installed on your machine the build worked fine, but there is
> a small possibility that you may still encounter intermittent crashes
> at runtime because the PHP headers are customized to match your build
> options by PHP's configure, and you didn't use the headers that match
> exactly your PHP build options. Options such as the version of REGEX
> or GD used by PHP have an impact on MapScript."
I guess this is what you meant...
I think I need to re-examine this install.
Daniel Morissette wrote:
> Are you using PHP as an Apache module or as a CGI?
> If using PHP as a module then what you got could be the symptoms of a
> memory trashing problem which over time corrupts/kills all Apache
> child processes.
> The easy workaround would be to switch to using PHP as a CGI, this way
> every request gets a new fresh process to work with and you avoid the
> problem.
> However if possible we should try to identify the source of the
> problem, and if it's a bug in MapServer then try to fix it.
> First, the usual suspects: GD... if your PHP has GD enabled, then is
> it using the same copy of GD as PHP MapScript? If PHP uses its bundled
> GD that could be a problem because MapScript likely uses the system GD
> and you have two different versions of GD used in the same process.
> It's important that both PHP and MapServer/MapScript use the system GD.
> If you are convinced that conflicting GD versions is not the cause of
> the problems then I'd suggest that you try again with MapServer 5.0.
> If you can reproduce the bug with 5.0 then please file a ticket in
> Trac with as much detail as you can, including a script + mapfile to
> reproduce.
> Daniel
> Bill Thoen wrote:
>> I've been experimenting with PHP/mapscript and came across an example
>> of how to display points dynamically (it's in the wiki at
>> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptAddPoint),
>> and so I wanted to try it.
>> It seems to work for several points in a row (basically moving a
>> single point to the next place I click) but after about 10 clicks or
>> so, the application dies with a loadLayer() error (which causes a
>> cascade of subsequent errors.) Worse, I discover that when this
>> happens NONE of my other PHP/mapscript applications will work, even
>> though they've been working fine and use other data sources and map
>> files. I have to reboot my machine to get them to work again.
>> I've added a call to $pt->free() following the line with $pt->draw()
>> in it and fixed the parameter list in click2map() to include the
>> $map->extent, but that doesn't seem to cure it.
>> I'm using MapServer 4.10.0 and I think mapscript 4.8, and this is all
>> running on Fedora Core 5 Linux machine.
>> Does anyone have any idea what's happening and how I can correct it?
>> TIA,
>> - Bill Thoen
