SLD not working on linux Fedora Core 5
Ruben Pardo
correosig at GMAIL.COM
Mon Nov 5 11:23:25 EST 2007
Thanks to Tom, the problem was solved.
I put in the httpd.conf
Alias /tmp/ "/usr/local/apache2/apps/mosaico_sandbox/htdocs/tmp"
having my tmp directory in
and in the mapfile
IMAGEURL tmp/
IMAGEPATH "/tmp/"
and also de OGR correctly installed in the linux.
2007/11/5, Ruben Pardo <correosig at gmail.com>:
> Thanks Tom,
> when i do a GetCapabilities request on Linux i get
> <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
> RemoteWFS="0"/>
> on windows i get the same ...
> RemoteWFS="0"/>
> I've got differents ports because i've got two servers, an oc4j that
> generate SLD's, and
> a apache with mapserver. The SLDs are visible from the mapserver machine.
> I also test with a SLD in
> the same server, but i doesn't work
> thanks
> 2007/11/5, Kralidis,Tom [Burlington] < Tom.Kralidis at ec.gc.ca>:
> > Hi,
> > A couple of initial ideas:
> > - when you do a GetCapabilities request on Windows, do you get the
> > following within the XML:
> > RemoteWFS="0"/>
> > - I notice that the SLD is on a host with a different port. Can the WMS
> > box see the box of the SLD document (not sure if your example below is
> > actual or has been modified for the list)
> > ..Tom
> > ________________________________
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ruben Pardo
> > Sent: 05 November, 2007 5:56 AM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] SLD not working on linux Fedora
> > Core 5
> > Hi everybody,
> > I'm using mapserver attaching SLD to a mapserver request. On
> > windows the same request, with the same mapfile, with the same SLD
> > works perfectly but it doesn't with my linux configuration.
> > I read that the only thing that i need to get working SLD is
> > OGR.
> > works with windows.
> > what could id do? where can i see what it happens?
> > The request is:
> > http://localhost/cgi-bin/mapserv?map=/usr/local/apache2/apps/mosaico_san
> > dbox/htdocs/prbmosaico.map&service=WMS&request=GetMap&Layers=Municipios&
> > version=1.1.1&SLD=http://localhost:8989/mosaico/jspx/sig/tmp/prb.xml
> > <http://localhost/cgi-bin/mapserv?map=/usr/local/apache2/apps/mosaico_sa
> > ndbox/htdocs/prbmosaico.map&service=WMS&request=GetMap&Layers=Municipios
> > &version=1.1.1&SLD=http://localhost:8989/mosaico/jspx/sig/tmp/prb.xml>
> > My linux mapserver version is:
> > MapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> > SUPPORTS=FASTCGI SUPPORTS=THREADS INPUT=TIFF INPUT=EPPL7 INPUT=SDE
> > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> > The linux os is:
> > 2.6.15-1.2054_FC5
> > thanks a lot.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071105/4dda8657/attachment.html
