SLD resquest issue with EXPRESSION parameter
Yewondwossen Assefa
yassefa at DMSOLUTIONS.CA
Mon Nov 5 14:14:49 EST 2007
I was able to reproduce this and the fix is commited in MapServer svn.
Ticket related to this is http://trac.osgeo.org/mapserver/ticket/2386.
Please comment in ticket if that solved your problem and I will close
the bug.
Best Regards,
Jacolin Yves wrote:
> Hi list,
> I am using Mapserver as a OGC webserver. I am trying the GetStyles request and
> find some issues. Someone asked about this issue in the mailing list in the
> short last few monthes.
> I got some LAYER which contains about 12 CLASS objets, this CLASS contains
> EXPRESSION parameter. Here an exemple :
> CLASS
> NAME "M1 : La Défense - Château de Vincennes"
> EXPRESSION ('[TYPE]' eq 'M' AND '[NUMERO]' eq '1' AND '[DATE_LIV]'
> < '200712')
> COLOR 255 255 0
> SIZE 3
> SYMBOL 1
> END
> There are 24 class like this one.
> If I try a GetStyles request on this kind of layer, nothing occurs (ie blank
> page), if I remove most CLASS the XML response is displayed, If I remove only
> the EXPRESSION parameter, again the XML response is displayed. So I think the
> issue is not link to the number of CLASS object, but rather with EXPRESSION
> parameter.
> BUT, in an other LAYER, I got only three CLASS object with EXPRESSION
> parameter, and the xml response is displayed.
> Finally, it seems that if a LAYER got a lot of CLASS object with EXPRESSION
> parameter inside, the XML response failed. And if a LAYER object got a lot of
> CLASS object, the XML response failed as well.
> I am using Mapserver 4.10. Are someone aware of this issue and know a
> workaround.
> Thanks,
> Y.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
