Labeling roads
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Nov 6 16:00:07 EST 2007
I create a separate ANNOTATION lay as Steve L suggests in his example to
add the shields. You can also add a MINDISTANCE 200 to make sure no two
shields with the same number are withing 200 pixels of one another.
-Steve W
Andre Schoonbee wrote:
> Thanks Steve, but may I be blond...
> In my layer definition, I have specified the line type as follows, - can I
> simply add the Style for the shield.png at the end of my 2 styles, or at
> what stage do I define the "Labeling symbol"?
> NAME "Roads"
> STATUS ON
> TYPE ANNOTATION
> STATUS DEFAULT
> # TYPE LINE
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres password=postgres dbname=posgis_ascii
> host=localhost port=5432"
> DATA "the_geom from roads"
> CLASSITEM "type" # field used by EXPRESSION in class objects
> # Begin classes for Freeways
> CLASS
> EXPRESSION ('[type]' = 'Freeway')
> NAME "Freeways"
> MAXSCALE 1000000
> MINSCALE 500001
> STYLE # Draw the outline
> SYMBOL 'circle'
> COLOR 0 0 0
> SIZE 6
> END
> STYLE # Draw the center redline
> SYMBOL 'circle'
> COLOR 255 0 0
> SIZE 4
> END
> END
> Regards
> Andre
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Steve Lime
> Sent: Tuesday, November 06, 2007 4:58 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Labeling roads
> Hi Andre: You use annotation layers. I think the demo shows this off. A
> layer
> would look like:
> LAYER
> NAME 'road_anno'
> TYPE ANNOTATION
> STATUS DEFAULT
> DATA 'roads'
> LABELITEM 'roadnum'
> CLASS
> STYLE
> SYMBOL 'shield.png'
> END
> LABEL
> COLOR 0 0 0
> SIZE TINY
> END
> END
> END
> Steve
>>>> Andre Schoonbee <andresch at IWAY.NA> 11/05/07 8:32 AM >>>
> How can I label a road by using the state symbol and putting the road no on
> top of it?
> Andre
