Mapserver and MySQL
Howard Butler
hobu.inc at GMAIL.COM
Wed Nov 7 01:30:54 EST 2007
Vishal,
You likely need to have the mysql-devel package installed on your
system. It contains the header files need to compile libraries
against the mysql API.
Howard
On Nov 6, 2007, at 11:34 PM, Vishal Nagpal wrote:
> I tried to install OGR with mysql support
> confiure was OK
> --with-mysql=/usr/lib/mysql/mysql_config
> but I got these errors during make. I had done make clean
> ogr_mysql.h:34:23: error: my_global.h: No such file or directory
> ogr_mysql.h:35:19: error: mysql.h: No such file or directory
> ogr_mysql.h:73: error: ISO C++ forbids declaration of 'MYSQL_RES'
> with no type
> ogr_mysql.h:73: error: expected ';' before '*' token
> ogr_mysql.h:169: error: 'MYSQL_RES' has not been declared
> ogr_mysql.h:194: error: ISO C++ forbids declaration of 'MYSQL' with
> no type
> ogr_mysql.h:194: error: expected ';' before '*' token
> ogr_mysql.h:210: error: ISO C++ forbids declaration of 'MYSQL' with
> no type
> ogr_mysql.h:210: error: expected ';' before '*' token
> ogr_mysql.h:213: error: expected `;' before 'int'
> mySQL is installed and running properly from command line,
> OS is Fedora 6.2
> Regards,
> Vishal
