System Configuration
Ed McNierney
ed at TOPOZONE.COM
Wed Nov 7 23:34:20 EST 2007
Bruce -
My channeling sensors went off when Frank rang <g>.
It is certainly true that a bit of experience and contemplation can help you discover optimization opportunities that aren't immediately self-evident. Can you describe the nature of your map application? Are you using raster data, vector data, or both? What size is your data, in numbers of features and/or files? What kind of disk subsystem is being used? Is there layer reprojection going on?
Generalizations are rarely helpful (except for this one). It's like being told the average man is 5' 7" tall - it tells you nothing about how tall I am. MapServer performance depends on a number of factors, but the best place to start is a detailed understanding of what exactly you're trying to do with MapServer.
It would be most helpful to us if you could post your map file and a sample URL request, preferably one that is externally (publicly) visible. And can you define what you mean by "simultaneous" users? Do you mean 5,000 map requests all being generated at exactly the same time? Or do you mean 5,000 human users asking for a new map every X seconds or so? And if the latter, what value are you using for X?
- Ed
Ed McNierney
Chief Mapmaker
Demand Media / TopoZone.com
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: 978-251-4242, Fax: 978-251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Frank Warmerdam
Sent: Wednesday, November 07, 2007 8:26 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] System Configuration
Bruce Cheney wrote:
> We have been given a requirement to support 5000 simultaneous users.
> What we are finding is that MapServer bogs down around 400 simultaneous
> users on a test machine. It looks like it is likely slowing because of
> the threading issue. We haven't tested on a production machine but are
> estimating that it should support double what are test machine could
> handle (double the processor and RAM). So at least 800 simultaneous
> users. Divide that out with the 5000 and we need a minimum of 6-7 web
> servers supporting MapServer. We will certainly scale this as is needed
> but I do need some idea going in as to what is going to be required.
Bruce,
I'm curious how many map requests per minute you expect 800 simultaneous
users to generate.
> Does this sound like results that others expect or is this quantity
> above what others have tested? Also Does anyone know of a solution in
> the works to run make mapserver thread safe and/or up the overall
> speed? I am not complaining about the speed just wondering what is in
> the works.
In various aspects MapServer is already thread safe though there are
also known "unsafe" components, and some components are wrapped by
big locks that significantly reduce the value of multiple threads.
Progress occurs by fits and starts, largely based on support from user
organizations depending on multi-threading. For instance, in 5.0 I
implement locking around OGR for a client of mine in Australia.
(This is a subtle way of suggesting you hire someone to make this
happen if it is what you want!)
All this aside, by default MapServer is *massively multi-threaded*.
I say this since the default operation is to start a new cgi instance
for each request - each is essentially an independent thread.
Of course, the downside of whole-process cgi style multithreading is
that very little context is preserved from request to request. Map
files, data file headers, etc all need to be reparsed for each request.
My point here is that you need to think carefully about the application
flow to take much advantage of multiple threading within a single process.
Also, if I may channel Ed, if you wanted to squeeze more performance out
of mapserver, you really need to start by figuring out what it is spending
it's time doing. Where is it spending it's time?
o waiting for disk? (perhaps you are reading more data than you need?)
o rendering (perhaps your data is overdense, or you are using expensive
rendering options?)
o parsing mapfiles (perhaps you mapfile has too many unused layers?)
etc.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
