PostGIS Queries using FILTER
Kyle Wilcox
Kyle.Wilcox at NOAA.GOV
Thu Nov 8 09:40:21 EST 2007
Seems to be a bug in Mapserver. Thanks to Armin of pmapper for helping
with the problem.
To get it to work correctly, I just added the filter line into the query
directly:
DATA "the_geom from (SELECT * from forecast left join grid on
grid.gid=forecast.grid_id where time=TIMESTAMP'2007-11-06 00:00:00') as
data USING UNIQUE gid USING SRID=4326"
Kyle Wilcox wrote:
> I just added that layer name into the mail code to avoid confusion, they
> are named by their timestamp's index For example:
> First layer:
> LAYER
> NAME 'One'
> FILTER "time=TIMESTAMP'2007-11-06 00:00:00'"
> METADATA 'DESCRIPTION' '2007-11-06 00:00:00' END
> END
> Second Layer:
> LAYER
> NAME 'Two'
> FILTER "time=TIMESTAMP'2007-11-06 03:00:00'"
> END
> Those are the only differences between layers.
> Could it be that the queryByPoint() function is querying on the specific
> point and applying the filter, which fails or returns all timesteps
> associated with that point, because the 'time' column is in a separate
> table than the geometry column? I assumed the queryByPoint() function
> would join my grid and data tables as specified in DATA. The grid
> geometry (POINTS) are in a separate table than the data (values I want
> returned from a query).
> The query code is coming from the pmapper framework. I'll set up a
> small test case using Mapserver 4.10 and a self made application to see
> if the same thing happens.
> Thanks for the response!
> Steve Lime wrote:
>> Attribute queries use filters themselves so any predefined filter is set aside temporarily. That said, for other
>> types of purely spatial queries the FILTER should remain intact. I just stepped through the point query code
>> and couldn't any place where it was mucked with.
>> What does the code that does that's doing the query look like? I notice in your sample layer that the layer
>> name is 'NAME' which makes me wonder if somehow you're always querying the same layer. Not to say that
>> there isn't something else going on as you suggest but I'll start with the obvious.
>> Steve
>>>>> On 11/6/2007 at 4:00 PM, in message <4730E3F5.2080000 at Noaa.gov>, Kyle Wilcox
>> <Kyle.Wilcox at NOAA.GOV> wrote:
>>> Did the usual searching without finding anything relevant.
>>> The application I am referencing is at:
>>> http://155.206.18.162/mapping/map/map.phtml
>>> I have time series data in a PostGIS enabled database (current and wind
>>> fields from model output). I can display the point data without
>>> problems (try any of the current or wind layers).
>>> The problem is that when querying a point layer, the data that is always
>>> extracted from the first timestamp rather than the timestamp associated
>>> with the layer I am trying to query (specified as a FILTER). I understand
>>> what is happening.. the query by point functionality is querying the
>>> database at the specific POINT and displaying the first row that returns
>>> (the first timestamp). If I delete the first timestamp data, the second
>>> timestep data is displayed and so on. The only thing that changes
>>> between layers is the FILTER.
>>> Does the queryByPoint() function utilize the FILTER definition from the
>>> mapfile? It doesn't seem to be doing so.
>>> (Mapserver 5.0 and PHP/Mapscript)
>>> Here is a sample layer definition:
>>> LAYER
>>> TYPE POINT
>>> CONNECTIONTYPE postgis
>>> NAME 'NAME'
>>> CONNECTION 'host=HOST user=USER dbname=DATABASE'
>>> grid on grid.gid=forecast.grid_id) as data USING UNIQUE gid USING
>>> SRID=4326"
>>> METADATA
>>> 'RESULT_FIELDS'
>>> 'wind_speed,wind_from_direction,rotation'
>>> 'RESULT_HEADERS' 'Wind Speed (m/s), Wind
>>> Direction (from TN), Rotation of Image (from TN)'
>>> 'LAYER_ENCODING' 'UTF-8'
>>> END
>>> STATUS OFF
>>> PROJECTION
>>> 'init=epsg:4326'
>>> END
>>> TOLERANCE 10
>>> TOLERANCEUNITS pixels
>>> LABELMAXSCALE 60000
>>> TEMPLATE void
>>> CLASS
>>> NAME ">= 0.95 m/s"
>>> EXPRESSION ([wind_speed] >= 0.95)
>>> STYLE
>>> SYMBOL "arrow2"
>>> ANGLE [wind_from_direction]
>>> COLOR 118 0 0
>>> OUTLINECOLOR 0 0 0
>>> SIZE 10
>>> END
>>> TEXT ([wind_speed] m/s - [wind_from_direction] TN)
>>> LABEL
>>> COLOR 118 0 0
>>> OUTLINECOLOR 0 0 0
>>> POSITION AUTO
>>> SIZE small
>>> PARTIALS TRUE
>>> END
>>> END
>>> END
>>> Kyle Wilcox
>>> NOAA Chesapeake Bay Office
>>> 410 Severn Avenue
>>> Suite 107A
>>> Annapolis, MD 21403
>>> office: (410) 295-3151
>>> Kyle.Wilcox at noaa.gov
>>> "It is from the wellspring of our despair and the places
>>> that we are broken that we come to repair the world."
>>> - Murray Waas
Kyle Wilcox
410 Severn Avenue
Suite 107A
Annapolis, MD 21403
- Murray Waas
