Installation Problem when Configuring
Matthew Pulis
mpulis at GMAIL.COM
Mon Nov 12 05:52:56 EST 2007
I am trying to configure the installation of Mapserver, and this is the line I am
using for configure :
yancho at Ubuntu:~/mapserver-5.0.0$ ./configure --with-postgis=/usr/lib/
postgresql/8.1/bin/pg_config --with-jpeg --with-xml2-config=/usr/bin/xml2-
config --with-sos with-threads --with-httpd=/etc/apache2 --with-ogr=/usr/
bin/gdal-config --with-ogr=/usr/bin/gdal-config --with-wcs --with-wfsclient --
with-wmsclient --with-geos=/usr/bin/geos-config
and this is the error I am getting :
checking if GEOS support requested... yes
user supplied geos-config (/usr/bin/geos-config)
checking for GEOS version >= 2.2.2... no
configure: error: geos-config reports version 2.1.4, need at least 2.2.2 or
configure --without-geos
I tried to check on Ubuntu packages from where to upgrade geos-config but
found nowhere .. any idea what I can do please?
Thanks beforehand :)
