Migrating from Windows to Linux: trouble with mapfiles
Steven De Vriendt
gisaalter at GMAIL.COM
Wed Nov 14 10:35:32 EST 2007
Solved this one too :-) thanks !
Still can't see my layers. Maybe 'cause I'm using PostGIS ?
However, I can acces my postgis-db from qgis without any trouble.
Anything I should be aware of when configuring a mapfile i/c postgis in
linux ?
On Nov 14, 2007 4:15 PM, Gregor Mosheh <gregor at hostgis.com> wrote:
> Steven De Vriendt wrote:
> > msEvalRegex(): Regular expression error. String
> > (/etc/mapserver/wmsserver.map?) failed expression test.
> Mapfiles must end in a .map extension.
> Taker out that extra ? character. It should probably be a & yes?
> Gregor Mosheh / Greg Allensworth
> System Administrator, HostGIS cartographic development & hosting services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
> only if you can restore." - AMANDA
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071114/6323215c/attachment.html
