Java Mapserver app - queryLayerByPoint. How?
Jeresin
info at JERESIN.CO.ZA
Thu Nov 15 03:16:58 EST 2007
Umberto Nicoletti wrote:
> The code snippet is actually missing the code for this function which
> does the trick of fetching a shape's value and putting them into a map
> for later use:
> protected Map getResult(shapeObj shape, layerObj layer) {
> Map aResult = new HashMap();
> for (int z = 0; z < shape.getNumvalues(); z++) {
> aResult.put(layer.getItem(z), shape.getValue(z));
> return aResult;
> Regards,
> Umberto
Thanks Umberto, I'm going to give it a try and get back to you with the
outcome.
View this message in context: http://www.nabble.com/Java-Mapserver-app---queryLayerByPoint.-How--tf4800141.html#a13763410
Sent from the Mapserver - User mailing list archive at Nabble.com.
