Problems with Java Mapscript
Luis Conti
conti_lui at GVA.ES
Mon Nov 19 05:50:21 EST 2007
Sorry, my last message don't see correctly.
Hello:
I'm new using Java Mapscript but I can't execute the examples (DrawMap.java)
with my testmap.map.
This is my system.
Linux OpenSuse 10.2
mapserv -v results
MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=EPPL7 INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
Java -v results
java version "1.5.0_08"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_08-b03)
Java HotSpot(TM) Client VM (build 1.5.0_08-b03, mixed mode, sharing)
the Java IDE is netbeans 5.5.1
This is my testmap file:
MAP
NAME servidor
EXTENT 626680 4191039 817176 4519393
SYMBOLSET "etc/symbol.sym"
FONTSET "etc/fonts.txt"
IMAGECOLOR 255 153 255
IMAGETYPE jpeg
RESOLUTION 96
WEB
IMAGEPATH "/var/www/tmp"
IMAGEURL "/tmp"
METADATA
"wms_title" "servidor wms icv"
"wms_online_resource"
"wms_srs" "EPSG:23030 EPSG:25830 EPSG:4230 EPSG:4258"
END
END
REFERENCE
EXTENT 626690 4186545 823410 4519390
IMAGE "./key_map.png"
SIZE 150 200
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
PROJECTION
"init=epsg:23030"
END
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
FORMATOPTION "QUALITY=100"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
TRANSPARENT ON
FORMATOPTION "INTERLACE=ON"
END
OUTPUTFORMAT
NAME gif
DRIVER "GD/gif"
MIMETYPE "image/gif"
IMAGEMODE PC256
EXTENSION "gif"
TRANSPARENT ON
END
LAYER
NAME "rios_principales_1000"
GROUP "Hidrografía"
CONNECTION "host=****** port=****** dbname=capas user=*******
password=******"
CONNECTIONTYPE Postgis
DATA "the_geom from rios_principales_1000"
TYPE LINE
METADATA
"wms_name" "rios_principales_1000"
"wms_group_title" "Hidrografía"
END
CLASS
NAME "riosPpal1000"
TITLE ""
SIZE 4
COLOR 0 112 255
LABEL
ANGLE AUTO
MINDISTANCE 1500
COLOR 190 232 255
OUTLINECOLOR 0 112 255
SIZE 8
TYPE truetype
FONT "fritqat-italic"
POSITION auto
END
END
STATUS ON
END
END
The same testmap.map works fine with php_mapscript.
When execute the DrawMap.java example crash in the line (43)
imageObj img = map.draw();
This is the error:
Exception in thread "main" java.lang.UnknownError: Unable to initialize
image.
at edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw (Native Method)
at edu.umn.gis.mapscript.mapObj.draw(mapObj.java:382)
at es.gva.icv.jmapscript.DrawMap.main(DrawMap.java:43)
I have searched about this error in internet, but I have found nothing.
Thanks in advance.
Luis Conti
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071119/1108fd12/attachment.html
