VS: [UMN_MAPSERVER-USERS] Mapserver as WMS server: every layer
contains all
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Mon Nov 19 06:02:54 EST 2007
Sure, yes. Try changing them to to ON.
-Jukka-
Lähettäjä: Francesco Sozzi [mailto:fsozzi at intercad.ch]
Lähetetty: 19. marraskuuta 2007 12:30
Vastaanottaja: Rahkonen Jukka; MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: Re: [UMN_MAPSERVER-USERS] Mapserver as WMS server: every layer contains all
All layer are DEFAULT. Do you think it could be a problem?...
----- Original Message -----
From: Rahkonen Jukka <mailto:Jukka.Rahkonen at MMMTIKE.FI>
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Monday, November 19, 2007 10:38 AM
Subject: Re: [UMN_MAPSERVER-USERS] Mapserver as WMS server: every layer contains all
What STATUS do you have in the layer definitions?
-Jukka Rahkonen-
Lähettäjä: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Puolesta Francesco Sozzi
Lähetetty: 19. marraskuuta 2007 11:19
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: [UMN_MAPSERVER-USERS] Mapserver as WMS server: every layer contains all
Hi All,
I have a problem on using mapserver as WMS server.
If I try to open by ArcGis or Autodesk Map a mapserver project, I get all on every layer. If I switch off all layer except one (for every one) everithing is displayed.
The layer list (and groups) is correct, but each layer contains all.
Anybody has experimented the same problem?
Best regards
Francesco
__________ Informazione NOD32 2666 (20071119) __________
Questo messaggio è stato controllato dal Sistema Antivirus NOD32
http://www.nod32.it
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071119/d532fc61/attachment.html
