query postgis through wms
Jørn Vegard Røsnes
jorn at SPACETEC.NO
Mon Nov 19 08:34:56 EST 2007
try to add the column to the tables
alter table <table> add column oid integer;
On Monday 19 November 2007 14:27, Steven De Vriendt wrote:
> Jorn,
> I have the following columns:
> gid
> capakey
> percid
> capaty
> shape_area
> the_geom
> Thanks for helping out !
> Steven
> On Nov 19, 2007 2:21 PM, Jørn Vegard Røsnes <jorn at spacetec.no> wrote:
> > Hi,
> > do you have a column named oid with integer type in your table?
> > cheers
> > Jørn Vegard
> > On Monday 19 November 2007 09:48, Steven De Vriendt wrote:
> > > Hi folks,
> > > I'm trying to query a postgis-layer through wms. Yet, I do not get any
> > > query results.
> > > Can anyone have a look at my mapfile. I have tried to label my features
> > > too, using
> > > a field of the postgis-table, but that doesn't seem to work too. So, my
> > > guess it should
> > > be something wrong in my map-file. Thanks for helping out !
> > > # Start of map file
> > > # Sample map file for a chameleon app.
> > > NAME DEMO
> > > STATUS ON
> > > SIZE 600 500
> > > SYMBOLSET symbols.sym
> > > EXTENT 77336.359625 189988.500250 90937.297125 201812.968625
> > > UNITS METERS
> > > SHAPEPATH "../data"
> > > IMAGECOLOR 255 255 255
> > > FONTSET fonts.txt
> > > TRANSPARENT FALSE
> > > WEB
> > > IMAGEPATH "etc/mapserver/tmp/ms_tmp"
> > > IMAGEURL "/tmp/"
> > > METADATA
> > > "wms_title" "Aalter_WMS"
> > > "wms_onlineresource" "
> > > "wms_srs" "EPSG:31300"
> > > END
> > > END
> > > OUTPUTFORMAT
> > > NAME png
> > > DRIVER "GD/PNG"
> > > MIMETYPE "image/png"
> > > IMAGEMODE PC256
> > > EXTENSION "png"
> > > END
> > > SCALEBAR
> > > LABEL
> > > COLOR 0 0 0
> > > SIZE SMALL
> > > END
> > > SIZE 150 5
> > > COLOR 255 255 255
> > > BACKGROUNDCOLOR 0 0 0
> > > OUTLINECOLOR 0 0 0
> > > UNITS meters
> > > INTERVALS 5
> > > STATUS ON
> > > END
> > > QUERYMAP
> > > STATUS ON
> > > SIZE 200 200
> > > STYLE HILITE
> > > COLOR 255 0 0
> > > END
> > > PROJECTION
> > > "init=epsg:31300"
> > > END
> > > LAYER
> > > NAME "Grens"
> > > METADATA
> > > "wms_title" "gemeentegrens"
> > > "gml_include_items" "all"
> > > END
> > > CONNECTIONTYPE postgis
> > > CONNECTION "host=""
> > > DATA "the_geom from alr_gemline"
> > > DUMP TRUE
> > > TEMPLATE "ttt"
> > > TYPE LINE
> > > CLASS
> > > NAME "KadScan"
> > > OUTLINECOLOR 208 208 208
> > > END
> > > PROJECTION
> > > "init=epsg:31300"
> > > END
> > > END
> > > LAYER
> > > NAME "Percelen"
> > > CONNECTION "host="" <http://192.168.102.100/>
> > > DATA "the_geom from b_capa_percid"
> > > TEMPLATE "ttt"
> > > LABELITEM 'capakey'
> > > TYPE POLYGON
> > > CLASS
> > > NAME "KadScan"
> > > END
> > > METADATA
> > > "wms_title" "percelen"
> > > END
> > > PROJECTION
> > > "init=epsg:31300"
> > > END
> > > END
> > > END # Map File
