query postgis through wms
Marcos Sánchez Provencio marcos at BURKE.ATH.CX
Mon Nov 19 06:41:38 PST 2007
Try using the srid your data is stored in instead of 31300. You might
use the function getsrid
SELECT getsrid(the_geom) from b_capa_percid limit 1;
El lun, 19-11-2007 a las 15:26 +0100, Steven De Vriendt escribió:
> Marcos,
> When I try your suggestion Mapserver returns:
>     <ServiceExceptionReport version="1.1.0">
>     <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'percelen'.
> msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
> statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
> (SELECT * FROM b_capa_percid) AS foo WHERE the_geom &&
> setSRID('BOX3D( 76945.5918856108 189996.502536997,91328.1081143621
> 201805.497460877)'::BOX3D, 31300 )
> -ERROR:  Operation on two geometries with different SRIDs
> </ServiceException>
> </ServiceExceptionReport>
> On Nov 19, 2007 3:19 PM, Marcos Sánchez Provencio
> <marcos at burke.ath.cx> wrote:
>         try
>         DATA "the_geom from (SELECT * FROM b_capa_percid) as foo
>         using srid=31300 using unique gid"
>         El lun, 19-11-2007 a las 09:48 +0100, Steven De Vriendt
>         escribió:
>         > DATA "the_geom from b_capa_percid"
More information about the MapServer-users mailing list
