How to label for each feature base on their angle?
    Steve Lime
    Steve.Lime at DNR.STATE.MN.US
    Mon Nov 19 21:57:19 PST 2007
For 5.0 that syntax has changed and apparently the docs haven't been
updated.
Instead of LABELANGLEITEM bind the LABEL ANGLE property using syntax
like:
  ANGLE [labelangle]
Steve
>>> Brent Fraser <bfraser at GEOANALYTIC.COM> 11/19/07 10:13 AM >>>
Try
http://mapserver.gis.umn.edu/docs/reference/mapfile/layer
LABELANGLEITEM [attribute]
Item name in attribute table to use for class annotation
angles. Values should be in degrees.
For Example:
     LABELANGLEITEM "LabelAngle"
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Sunday, November 18, 2007 10:26 PM
Subject: [UMN_MAPSERVER-USERS] How to label for each feature
> I have a point shapefile with rotation angle attribute
field for each
> feature. How do i label these features based on that
field. In mapfile, i
> only set label angle for a layer but not for each feature
> Thanks in advance
> Best regards,
> Le Viet Thanh
> GIS Technician - GIS Team
> __________________________________
> Vietnam - Denmark VIDAGIS CO., LTD
> 5 Lang Ha Str, Hanoi, Vietnam
> Tel: +84 4 5145570  Fax: +84 4 5145571
> http://www.vidagis.com
> Direct: thanhlv at vidagis.com      +84 984 468147
More information about the MapServer-users
