query postgis through wms
Richard Duivenvoorde
rdmailings at DUIF.NET
Tue Nov 20 02:37:35 EST 2007
Hi Steven,
there are some srid related places places:
1) if you added the column using AddGeometryColumn
SELECT AddGeometryColumn('public', 'kaas', 'wkb_geometry_rd', 28992,
'POINT', 2)
a record is added to 'geometry_columns' where you can find the srid for
that table
2) every geometry in the table also holds a srid. Find out bij looking
at the geometries as GML:
select AsGML(wkb_geometry) from kaas
or just ask for the srid:
select getsrid(wkb_geometry) from kaas
besides that be sure your projection is defined in the spatial_ref_sys
table (and if you reproject, into the proj definitions of mapserver).
But 31300 ("Belge 1972 / Belge Lambert 72") shouldn't be the problem.
Biggest problem is probably that mapserver asks for 31300, and your
columns OR you geometry_columns -table hold different OR mixed(!) srids.
Be sure your data is all one srid and the srid-value in geometry_columns
corresponds to that.
It's very easy to reproject in postgis:
First add a new column with the new epsg (for example 4326):
SELECT AddGeometryColumn('public', 'kaas', 'wkb_geometry_4326', 4326,
'POINT', 2)
then fill it using:
UPDATE kaas SET wkb_geometry_4326 = Transform(wkb_geometry, 4326)
If your data is ok, it doesn't mather anymore what mapserver is calling
for, because (if the srid/epsg is defined in the web-part of you
mapfile) mapserver will reproject it anyway.
Hope this helps a little :-)
Groeten,
Steven De Vriendt wrote:
> How can I see what SRID the data is using ? I'm quite new to all this...
> Steven
> On Nov 19, 2007 3:41 PM, Marcos Sánchez Provencio <marcos at burke.ath.cx
> <mailto:marcos at burke.ath.cx>> wrote:
> Try using the srid your data is stored in instead of 31300. You might
> use the function getsrid
> SELECT getsrid(the_geom) from b_capa_percid limit 1;
> El lun, 19-11-2007 a las 15:26 +0100, Steven De Vriendt escribió:
> > Marcos,
> > When I try your suggestion Mapserver returns:
> > <ServiceExceptionReport version="1.1.0">
> > <ServiceException>
> > msDrawMap(): Image handling error. Failed to draw layer named
> > 'percelen'.
> > msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
> > statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
> > asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
> > (SELECT * FROM b_capa_percid) AS foo WHERE the_geom &&
> > setSRID('BOX3D( 76945.5918856108 189996.502536997,91328.1081143621
> > 201805.497460877)'::BOX3D, 31300 )
> > -ERROR: Operation on two geometries with different SRIDs
> > </ServiceException>
> > </ServiceExceptionReport>
> > On Nov 19, 2007 3:19 PM, Marcos Sánchez Provencio
> > <marcos at burke.ath.cx <mailto:marcos at burke.ath.cx>> wrote:
> > try
> > DATA "the_geom from (SELECT * FROM b_capa_percid) as foo
> > using srid=31300 using unique gid"
> > El lun, 19-11-2007 a las 09:48 +0100, Steven De Vriendt
> > escribió:
> > > DATA "the_geom from b_capa_percid"
