NEW Mapserver Application
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Nov 21 11:20:36 EST 2007
Another strategy would be using OpenLayers as the client layer, and
mapserver CGI as the renderer called from OpenLayers and if you need
customized applications, write REST/AJax/JSON based applets on the
server in Perl/PHP/Python/Java/etc to service the Javascript in your
client and build a real Web 2.0 application.
-Steve W
Brant Anderson wrote:
> With the CGI you are passing arguments to the URL. The Mapfile has
> templates that it parses to create different views. With MapScript you
> are manipulating the map through code. In your case you would be using
> .NET MapScript API calls. Using MapScript, as far as I know, the
> templates are not used. Instead you'll have to write your own views.
> Steve's mapserv.js manipulates the CGI argument string. Look at the code
> for that, it has a wealth of starting point knowledge.
> http://maps.dnr.state.mn.us/tools/dbox/
> <http://maps.dnr.state.mn.us/tools/dbox/>
> In my opinion, the MapScript API is easier to work with because if you
> already know a web-programming language, you only need to learn the API;
> you don't need to figure out how to setup templates or how to manipulate
> Also, read this post:
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0311/msg00147.html
> To answer the unanswered question from that post:
> >>Why would I want to use Mapscript?
> You have favorite a web-programming language you like to write
> applications with.
> >>Which benefits does it give me?
> More flexible application development. A smaller learning curve (for me
> anyway).
> >>Simply better control?
> Yes. IMHO.
> Hope that helps,
> Brant
> On Nov 21, 2007 12:18 AM, Saka Royban < srph124 at yahoo.com
> <mailto:srph124 at yahoo.com> > wrote:
> Hi
> can i ask a basic question?
> what's the difference between using Mapscript and CGI?
> i'm a bit familiar with Asp.net <http://Asp.net> and its
> architecture of web programming but i'm confused about the different
> ways of prgramming UMN mapserver.
> THX
> ----- Original Message ----
> From: Brant Anderson <rabrant at GMAIL.COM <mailto:rabrant at GMAIL.COM>>
> To: MAPSERVER-USERS at LISTS.UMN.EDU <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Tuesday, November 20, 2007 5:14:42 PM
> Subject: Re: [UMN_MAPSERVER-USERS] NEW Mapserver Application
> >> Question 1 Can somebody suggest which is the best option to
> develop my
> >> application CGI or Mapscript..
> I agree with Marcos. The CGI is a good starting point to get your
> feet wet. That's where I began. Until one day I decided to take the
> leap. I'd recommend using MapScript with a language that you're
> comfortable with.
> I tried MapScript using Python. I found that I could develop an app
> easier using MapScript than with the CGI.
> Eventually, I started developing Ruby on Rails apps. So I thought
> I'd give Ruby/MapScript a try. I'm not sure what has changed in
> Ruby/MapScript since the 5.0.0 release. But I found that my
> application was buggy when I switched from 4 to 5. If you're going
> to try Ruby/MapScript, I'd recommend using version 4.10 of MapServer.
> >> Question 2 Which is the best software available for developing
> user
> >> interface. (Cartography). Is their a basic version available as
> a start
> >> point. like mapserver itasca demo.
> You stated that you're using Linux. You might want to look into
> Quantum GIS. I think there is a MapServer Mapfile Export feature. I
> haven't tried it, so I'm not sure how it works.
> Best Regards,
> Brant
> Get easy, one-click access to your favorites. Make Yahoo! your
> homepage. <http://us.rd.yahoo.com/evt=51443/*http://www.yahoo.com/r/hs>
