ms4w dlls for IIS-installation
Fortin,Nicolas [SteFoy]
nicolas.fortin at EC.GC.CA
Fri Nov 23 10:54:30 EST 2007
Hi!
You can open mapserv.exe with Dependency Walker http://www.dependencywalker.com/ and you'll see ALL the dll it needs.
Here are the mapserver specific ones I got with my own version
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
OCI.DLL
BGD.DLL
GDAL13.DLL
GEOS_C.DLL
ICONV.DLL
LIBCURL.DLL
LIBMAP.DLL
LIBXML2.DLL
PROJ.DLL
ZLIB1.DLL
Also, I never put the needed mapserver dlls in system32, instead I prefer to create a new folder, put the dlls in it and add it to the path. It's easier to keep your system clean and to upgrade to new version.
Nicolas
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Sven Schroeter
Envoyé : 23 novembre 2007 03:49
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] ms4w dlls for IIS-installation
Hallo,
I want to install the latest Mapserver 4.10 on a Windows 2003 Server with IIS (PHP 5.2.3 is already installed as cgi).
In older mapserver-versions I copied some .dlls in the system32 and the mapserv.exe in the cgi-bin of the IIS. Then php-mapscript in the ext-folder of php and everything worked fine.
With the install-packages ms4w (f.e. ms4w_2.2.5) there are many dlls in the cgi-bin (ms4w\Apache\cgi-bin) and I dont know what .dll are really used and important for mapserver and mapscript.
Some files are for apache or php5 (f.e. php5apache2.dll) .
Can anybody list the basic .dlls I need for a installation with IIS?
Thanks
Sven
