FME, POSTGIS and MAPSERVER
Guillaume Sueur
guillaume.sueur at NEOGEO-ONLINE.NET
Mon Nov 26 02:50:41 EST 2007
Hi
You should check the FME dataset's options you're creating the pg table
with. I've used FME a few times to export to pg, and I remember having
had to play around with options :
- geometry type of the new dataset : don't set to geometry, but to
proper geometric type (point, linestring, polygon...)
- projection of course.
also check the geometry_columns table of your database, there should be
a line about your dataset in here.
Good luck,
Guillaume
Lê Viết Thanh a écrit :
> Hi all, i have a problem in converting from Esri Shapefile to Postgis.
> If i use shp2pgsql tool to do, it's successful to read in Mapserver but
> with converting in FME is not successful.I cant understand what
> happened? Does anyone know?
> Thanks
> Best regards,
> Le Viet Thanh
> GIS Technician - GIS Team
> __________________________________
> Vietnam - Denmark VIDAGIS CO., LTD
> 5 Lang Ha Str, Hanoi, Vietnam
> Tel: +84 4 5145570 Fax: +84 4 5145571
> http://www.vidagis.com
> Direct: thanhlv at vidagis.com <mailto:thanhlv at vidagis.com> +84 984
> 468147
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 65 58 88 82
Site web : http://www.neogeo-online.net
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071126/443862d9/guillaume_sueur.vcf
