layerObj.queryByAttributes changed with Oracle
Benedikt Rothe
umn-ms at HYDROTEC.DE
Thu Nov 29 11:39:40 EST 2007
Hi Fernando
Thanks for your quick response!
Since in many cases the where-part is more complex the easiest solution
for me
is to omit the second parameter:
alayerObj.queryByAttributes(aMapObj, null,
"ID=4711",mapscript./MS_SINGLE/);
Mmmh. It looks like this parameter was useless all the time anyway!
Thank you very much!
Benedikt
PS: The documentation in
http://mapserver.gis.umn.edu/docs/reference/mapfile/referencemanual-all-pages
states, that FILTERITEM is only used in conjunction with OGR/Shapefile.
Fernando Simon <fsimon at univali.br> schrieb am 29.11.2007 16:57:40:
> Hi Benedikt,
> This is a Oracle Spatial driver change for 5.0. And the source of
> this issue was relate with some Filter/FilterItem problems for Oracle
> Spatial in early versions (4.x).
> The osFilterItem function in the source code is relate with FILTER
> and FILTERITEM definitions for Mapfile (you can see here:
http://mapserver.gis.umn.edu/docs/reference/mapfile/referencemanual-all-pages)
> and Mapscript. In the PHPMapscript, the info for queryByAttribute relate
> that the parameters that you pass will overwrite what you define for
> FILTER/FILTERITEM in Mapfile. In the same doc for queryByAttribute:
> "qitem is the item (attribute) on which the query is performed, and
> qstring is the expression to match."
> In the source code for 5.0 version this is a new (maybe better)
> interpretation for the docs. I believe that this new way is better when
> compared with the docs.
> Best regards.
> Fernando Simon
> Benedikt Rothe wrote:
> > Hello List
> > I'm using Mapserer with Oracle/Java-Mapscript and migrating my app
> > from Mapserver 4.x to Mapserer 5.x
> > and have a problem with layerObj.queryByAttributes.
> > I used to query features with code like this:
> > alayerObj.queryByAttributes(aMapObj, "ID", "ID=4711",
> > In Mapserver 5 this code results in an Mapserver-Error-Message
> > stating, that the "SQL command is not properly ended".
> > The Mapserver-generated SQL-Command includes a Where-Clause of the
> > form "ID = ID = 4711".
> > I had a look in maporaclespatial.c function "osFilteritem".
> > Follwing code seems to produce this Where-Clause:
> > if (layer->filteritem != NULL)
> > sprintf (query_str + strlen(query_str), " %s = ",
layer->filteritem);
> > //snprintf (query_str + strlen(query_str), " %s = ",
> > layer->filteritem);
> > Changing my Java-Code to
> > alayerObj.queryByAttributes(aMapObj, "ID", "4711",
> > solves the problem.
> > Questions:
> > * Is this a bug in Mapserver or a new feature?
> > * Is this really a change in Mapserver 5.0?
> > * Shall I rather change my Java-Code or shall I patch Mapserver/
> > maporaclespatial.c/osFilteritem?
> > Would the changed Java-Code work with the Oracle-driver only?
> > Greetings from Aachen/Germany
> > Benedikt Rothe
> > *Attachement "Error-Message": *(Added Newlines)
> > msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
> > ORA-00933: SQL command not properly ended
> > . Query statement:
> > SELECT
> > ID, ID, SHAPE
> > FROM
> > (select ID,SHAPE
> > FROM MYTABLE)
> > WHERE *ID = ID = 4711* AND
> > SDO_FILTER(
> > SHAPE, MDSYS.SDO_GEOMETRY(2003, 82015,
> > NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),
> > MDSYS.SDO_ORDINATE_ARRAY(2501576.69,5621567,2503419.31,5622567)
> > ),'querytype=window') = 'TRUE' .
> > Check your data statement.
> > *Attachement "Part of mapfile":*
> > # Projekte
> > LAYER
> > NAME "PROJEKT"
> > TYPE POINT
> > STATUS DEFAULT
> > #DEBUG ON
> > TEMPLATE "dummy.html"
> > CONNECTION "XXX/YYY at ZZZ"
> > CONNECTIONTYPE oraclespatial
> > DATA "SHAPE FROM (select ID,SHAPE FROM MYTABLE) using unique ID
> > srid 82015"
> > CLASS
> > NAME ""
> > STYLE
> > COLOR 0 100 100
> > OUTLINECOLOR 0 0 0
> > SIZE 12
> > SYMBOL 'star'
> > END
> > END
> > END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071129/7c960e12/attachment.html
