QUERYRESULT QUESTION
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Nov 29 13:48:53 EST 2007
In a querymap or ??? Sorta depends on how you are using the image in your application. You could,
for example, setup a special layer that is not normally drawn for this purpose. In your mapfile you'd
have:
# normal polygon layer
LAYER
END
# layer to hilite a polygon
LAYER
NAME 'hilite'
CLASSITEM 'primary_key'
CLASS
EXPRESSION '[primary_key_value]'
END
END
Then in your query results instead of using a query map you'd call mapserver, turning on the hilite layer
and passing in the primary key value for the selected polygon, for example:
<img src=".../cgi-bin/mapserv?...&layer=hilite&primary_key_value=[primary_key]&...">
That would work if you're using query templates. You could also query the hilite layer specifically, only
turning it on for queries and using a standard querymap. You get more flexibility in symbolization with
the first approach. Make sense?
Steve
>>> On 11/28/2007 at 9:27 AM, in message
<593449.506.qm at web38207.mail.mud.yahoo.com>, Carlos Ruiz
<boolean10001 at YAHOO.COM> wrote:
> Hello to all,
> I have a polygon layer, and i do a query by point operation, it's possible
> just to show the
> polygon's perimeter as selected instead the whole polygon ?
> Thanks in advance
> IC Carlos Ruiz
> Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it
> now.
