Color shifts using QUANTIZE_COLORS=256
rich.fromm
nospam420 at YAHOO.COM
Fri Nov 30 15:09:54 EST 2007
Stephen Woodbridge wrote:
> Thanks for the pointer to the bug. I will add some comments to it even
> though it is closed.
> Bart van den Eijnden (OSGIS) wrote:
>> there is some info by Frank in the following bug report (assuming it is
>> not outdated):
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=684
I think this may be just a rehashing of this same issue, which I think is
further covered in the following (the URL has moved):
http://trac.osgeo.org/mapserver/ticket/684
Trouble tricking Mapserver colors in 8-bit mode
Ticket #684 (closed defect: wontfix)
Although since that was opened 4 years ago, last modified more than 1 year
ago, and this thread is from the time (>1 year ago) of that last
modification,
I want to make sure that this is valid and I'm understanding things
properly.
I've narrowed this down to a very simple test case (see below). ALL that
I'm
attempting to displaying here is an 80% grey background. This works fine
with
both the AGG and GD rendering backends, as long as quantization is not
enabled. However, if I enable quantization, instead of getting a uniform
background of (204,204,204), I get (204,206,204). And I'm quite surprised
at
how visually noticeable such a small green shift is. I can preserve the
proper color if I use IMAGEMODE PC256 rather than IMAGEMODE RGB, but that is
only valid with GD. If I try to use it with AGG, I get the following error
message:
msDrawMap(): Image handling error. Unable to initialize
image. msPrepareImage(): GD library error. Unable to initialize
image. msImageCreateAGG(): AGG library error. AGG driver only supports RGB
or
RGBA pixel models.
I have a very strong preference for using AGG instead of GD. And I would
prefer to make my PNG's smaller by not using full 24bit color. I realize a
plain background is a bit of an extreme case, but in this case the size
difference is dramatic:
-rw-r--r-- 1 rich engr 2809 2007-11-30 11:14 agg.png
-rw-r--r-- 1 rich engr 133 2007-11-30 11:15 agg_q.png
-rw-r--r-- 1 rich engr 2809 2007-11-30 11:14 gd.png
-rw-r--r-- 1 rich engr 133 2007-11-30 11:37 gd_q.png
-rw-r--r-- 1 rich engr 133 2007-11-30 11:47 gd_256.png
And here are the color distributions within the images:
agg.png --------
0: (204,204,204) grey80
agg_q.png --------
0: (204,206,204) #CCCECC
gd.png --------
gd_q.png --------
gd_256.png --------
I realize that sometimes quantization will by its very nature need to change
colors, but I had not expected this if the input image already had a
sufficiently small number of colors.
Is this indeed still recognized as a known issue that is not going to be
fixed? One of the replies here suggested the possibility of reserving
colors
via a PALETTE option, but I can find no mention of this anywhere in the
docs.
I suppose another option would be to have mapserver output 24bit color PNG
images and use some external program (like ImageMagick) to convert to 8bit
PNG.
I am running mapserver-5.0.0, compiled with gd-2.0.35 and agg-2.5.
Complete map files to reproduce my testcases are included below.
- Rich Fromm
--- begin agg.map ---
MAP
NAME agg
IMAGETYPE AGG
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
EXTENT -122.293878 37.838295 -122.288122 37.841705
SIZE 640 480
IMAGECOLOR 204 204 204 # background
END
--- end agg.map ---
--- begin agg_q.map ---
MAP
NAME agg_q
IMAGETYPE AGG_Q
OUTPUTFORMAT
NAME 'AGG_Q'
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
SIZE 640 480
END
--- end agg_q.map ---
--- begin gd.map ---
MAP
NAME gd
IMAGETYPE PNG
OUTPUTFORMAT
NAME 'PNG'
DRIVER GD/PNG
IMAGEMODE RGB
END
SIZE 640 480
END
--- end gd.map ---
--- begin gd_q.map ---
MAP
NAME gd
IMAGETYPE PNG_Q
OUTPUTFORMAT
NAME 'PNG_Q'
DRIVER GD/PNG
IMAGEMODE RGB
END
SIZE 640 480
END
--- end gd_q.map ---
--- begin gd_256.map ---
MAP
NAME gd_256
IMAGETYPE PNG_256
OUTPUTFORMAT
NAME 'PNG_256'
DRIVER GD/PNG
IMAGEMODE PC256
END
SIZE 640 480
END
--- end gd_256.map ---
View this message in context: http://www.nabble.com/Color-shifts-using-QUANTIZE_COLORS%3D256-tf2080351.html#a14092078
Sent from the Mapserver - User mailing list archive at Nabble.com.
