STILL: WFS problem with tileindex and filter accepting by
Matti Silvennoinen
Matti.Silvennoinen at ARBONAUT.COM
Mon Oct 1 07:11:21 EDT 2007
Hi list,
I post this again. Has anyone found a solution for this. Tab files with
tileindex doesn't return any attributes and are not selectable using uDig.
We have following version running on Windows:
MapServer version 4.10.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PD
F OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPP
ORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPP
ORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
INPUT
=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG
We have problem with tileindexed tab-files when using those through
WFS-connection.
Tests:
- MapServer 4.10.1
- Client: uDig
- Data: TAB-files containing relative large dataset ~10 MB per file,
altohether more than 80 files. Geometry type is line. A file does not
contain unique attribute.
Cases:
- Single shp-file: everything works ok
- Single TAB-file: everything works ok
- shps with tileindex (tileindex created using ogrtindex) : all features
are visible, using info tool attribute info is readable, box selection
selects only one feature - possible bug
- tabs with tileindex (tileindex created using ogrtindex) : all features
are visible, using info tool NO attribute info is readable, box selection
does NOT select any feature - possible bug
We have also tried to create tileindex using tile4ms but the result is
same.
We found some bugs of MapServer that seems to relate to this issue.
However, developers have worked with those bugs already a long time ago.
#1615, #1616
The same query through MapServer - WFS - Oracle connection works OK
(native connection).
Any solution for this problem?
Matti Silvennoinen
