STILL: WFS problem with tileindex and filter accepting by
Frank Warmerdam
warmerdam at POBOX.COM
Mon Oct 1 12:22:09 EDT 2007
Matti,
I'm on the road currently, but if the problem persists I would encourage
you to follow up with me directly next week and I'll see if I can help. It
sounds like an "mapogr.cpp" problem. It would be very helpful if you
can boil this down to a minimal demonstration that can be filed via
Trac. The bug report should include example data, mapfile, and the
exact url to mapserver (something I can use with mapserver on the
commandline) to reproduce the problem.
Best regards,
On 10/1/07, Matti Silvennoinen <Matti.Silvennoinen at arbonaut.com> wrote:
> Hi list,
> I post this again. Has anyone found a solution for this. Tab files with
> tileindex doesn't return any attributes and are not selectable using uDig.
> Any solution for this problem?
> Matti Silvennoinen
and watch the world go round - Rush | Geospatial Programmer for Rent
