VS: [UMN_MAPSERVER-USERS] WMS Client Connection through a
proxy
Y. Calcagni
yvan.calcagni at VOILA.FR
Mon Oct 1 10:21:41 EDT 2007
On Fri, 28 Sep 2007 15:09:16 +0300, Rahkonen Jukka
<Jukka.Rahkonen at MMMTIKE.FI> wrote:
>> -----Alkuperäinen viesti-----
>> Lähettäjä: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Puolesta Kralidis,Tom
>> [Burlington]
>> Lähetetty: 28. syyskuuta 2007 15:01
>> Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
>> Aihe: Re: [UMN_MAPSERVER-USERS] WMS Client Connection through a proxy
>> > I'm trying as a WMS client to connect an OGC server through
>> a proxy,
>> > but all I'm getting is a blank image.
>> > I'm using Mapserver 4.6.1 with WFS_CLIENT support and here
>> is to code
>> > from the mapfile I'm using :
>> > LAYER
>> > CONNECTION
>> > "http://ogcrisques.brgm.fr/cgi-bin/mapserv?map=/application/ma
>> pserver/mapFiles/risquesIT.map?"
>> > CONNECTIONTYPE WMS
>> > METADATA
>> > "wms_srs" "EPSG:27582"
>> > "wms_exceptions_format" "application/vnd.ogc.se_xml"
>> > "wms_name" "DAT_SIREN_FS"
>> > "wms_proxy_*" "192.168.1.14:8080"
>> > "wms_format" "image/png"
>> > "wms_server_version" "1.1.1"
>> > END
>> > NAME "layerBD_MVT"
>> > PROJECTION
>> > "init=epsg:27582"
>> > END
>> > SIZEUNITS PIXELS
>> > STATUS ON
>> > TOLERANCEUNITS PIXELS
>> > TYPE RASTER
>> > UNITS METERS
>> > END
>> I'm not sure if this is supported (i.e. I don't see any proxy
>> type metdata in either WMS client or WFS client). Is the
>> CONNECTION URL only accessible via proxy?
>> ..Tom
>Hi,
>In MS4W installation proxy is handled in Apache httpd.conf file:
>SetEnv "http_proxy" "proxy.address:port"
>and possibly SetEnv "NO_PROXY" in a similar way.
>-Jukka Rahkonen-
Thanks, in fact it was my apache mod_env which wasn't set correctly. Now
everything works fine.
See you.
Yvan
