Problem with java mapscript
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Oct 11 17:50:59 EDT 2007
Mauro,
you have most likely hit a bug. Please file an issue on mapserver's trac at:
http://trac.osgeo.org/mapserver
and attach a simple test case with:
- a map file
- a short Java program showing the bug
- a small set of data (if necessary)
We'll look into this asap.
Thanks,
Umberto
On 10/11/07, maurosa at iol.it <maurosa at iol.it> wrote:
> Hi list
> I am using mapserver 5.0 with java mapscript.
> I use oracle spatial 10g.
> I have problems with long string (longer then 2k)
> used to specify complex data sql connection query or filter.
> When mapscript execute for instance setFilter it crashes.
> I suspect there is a general issue with long string.
> The same string used directly in the mapfile works correctly.
> It is probably a mapscript memory allocation problem.
> While I can use an oracle view to avoide the problem for the connection query, I do not know how to avoide it with the filter, because it is known only at run time.
> The filter can be something like:
> CODE IN ('1','2','3'....very long string ... '1000')
> Can this be set as a bug?
> Thank you for any suggestion
> Mauro Sartori
> Leggi GRATIS le tue mail con il telefonino i-mode™ di Wind
> http://i-mode.wind.it/
