label: autofollow
Young Kim
youngkkim at GMAIL.COM
Sun Oct 14 19:09:36 EDT 2007
Hello all,
I'm having trouble assigning "follow" angle to label obj.
I'm using PHP mapscript to generate images.
The following line throws error:
$class_obj->label->set("autofollow", MS_TRUE);
error msg:
PHP Fatal error: Property 'autofollow' does not exist in this object.
according to mapscript documentation,
http://mapserver.gis.umn.edu/docs/reference/mapscript/index_html#labelobj,
this should be available.
When i draw same layer via a map file and using "ANGLE follow",
everything works perfectly.
Am I missing something?
Thanks.
Versions:
MS - 5.1-dev, SVN trunk
php-5.2.3
