FONTSET problem on mac os x - empty rectangles in the image
Webb Sprague
webb.sprague at GMAIL.COM
Tue Oct 16 00:18:28 EDT 2007
On 10/15/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> The problem is that the arial /Library/Fonts/ArialHB.ttf font you are
> using is not the same encoding as the shapefile data.
Cool, and thanks for your help. But what is this "encoding" and how
do I fix it? I am using a postgis table, which I think is AASCII...
Is that the encoding of which you speak?
Tx
W
> -Steve
> Webb Sprague wrote:
> > I am attaching the file, but this didn't fix the problem. You can see
> > the empty boxes.
> > Thx, though ;)
> > -W
> >> Is this a transparent overlay layer? is IMAGECOLOR 0 0 0? if so then
> >> that color is transparent and you leters are also transparent. If that
> >> is the case change your label COLOR 1 1 1 and it should fix the problem.
> >> -Steve
> >> Webb Sprague wrote:
> >>> Hi again
> >>> I am trying to get labels based on a the "name" field in a postgis
> >>> table (of GNIS placenames). Everything works great (the overlay, the
> >>> triangle symbol, etc), but in the image, I get empty boxes where the
> >>> letters should be (though I get a one-to-one box to letter). If
> >>> anyone can help, I would sure appreciate it. (I am running a generic
> >>> mapserver from installed by fink.)
> >>> Here is the view definition in sql:
> >>> SELECT placenames.gid AS oid, placenames.name, placenames.desig,
> >>> placenames.elev, placenames.the_geom
> >>> FROM placenames
> >>> WHERE placenames.desig::text = 'airport'::text
> >>> ORDER BY placenames.gid;
> >>> Here is the my font file (yes, the files do exist):
> >>> MAPSCRIPT[2]$ cat fonts.list
> >>> arial2 /Library/Fonts/Arial
> >>> MAPSCRIPT[2]$
> >>> Here is the layer in my mapfile:
> >>> LAYER
> >>> NAME "airports"
> >>> CONNECTIONTYPE postgis
> >>> CONNECTION "user=wsprague dbname=or_gis host=localhost"
> >>> DATA "the_geom from airports_view"
> >>> STATUS DEFAULT
> >>> TYPE POINT
> >>> LABELITEM "name"
> >>> LABELCACHE ON
> >>> CLASS
> >>> NAME "LocationSymbol"
> >>> SYMBOL "triangle"
> >>> COLOR 100 100 82
> >>> LABEL
> >>> # OUTLINECOLOR 255 255 255
> >>> # MINDISTANCE 200 # Label only at close range
> >>> COLOR 0 0 0
> >>> TYPE TRUETYPE
> >>> SIZE 12
> >>> FONT "arial"
> >>> POSITION cc
> >>> ANGLE AUTO
> >>> PARTIALS FALSE
> >>> END #end label
> >>> END
> >>> END
