Solaris AGG Compile...
Trent Erickson
trente at UMN.EDU
Tue Oct 16 21:45:17 EDT 2007
The sunfreeware gcc package is compiled with --with-ld=/usr/ccs/bin/ld
so it can be hard to get around it. (you can see this by running g++ -v)
The sun ld version did not want to compile agg for me. I ended up
renaming /usr/ccs/bin/ld to /usr/ccs/bin/ld-off I then put it back
after the compile. This of course requires root access.
It is not very elegant but it worked. If anyone has any other
suggestions I'd love to know how to force the proper ld with resorting
to this. It just plain ignored the makefile and environment settings.
-Trent
Nolte, Tim wrote:
> OK, well here's my setup. I have the following sunfreeware packages
> installed:
> gcc-3.4.6-sol10-x86-local
> make-3.81-sol10-x86-local
> automake-1.10-sol10-x86-local
> libtool-1.5.24-sol10-x86-local
> I've set my PATH environment to use '/usr/local/bin' before
> '/usr/ccs/bin'. And my g++/gcc/make/ar/ld are all GNU when I run 'type'
> on them. I did notice that gcc reports (Configured with: ../configure
> --with-as=/usr/ccs/bin/as --with-ld=/usr/ccs/bin/ld --enable-shared
> --enable-languages=c,c++,f77) so I'm not sure if this would be an issue.
> Thanks for any other thoughts.
> Timothy J Nolte - tnolte at ilpcs.com
> Associate Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: Johan Van de Wauw [mailto:johan.vandewauw at gmail.com]
> Sent: Tuesday, October 16, 2007 9:58 AM
> To: Nolte, Tim
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] Solaris AGG Compile...
> It's been a while since I've worked with solaris, but you should try
> this
> make install CXX=g++ C=gcc AR=gar LD=gld
> (no need to edit the makefile)
> gar = gnu ar -> now you are using the one from suns's compiler. Idem
> for C and C++: make sure you don't mix up the gnu and the sun tools.
> idem for ld and the other tools.
> On 10/16/07, Nolte, Tim <Tim.Nolte at ipcswirelessinc.com> wrote:
>> OK, so a standard 'make' would work, erroring on CC not being defined.
> I
>> made the following changes to Makefile.in.SunOS:
>> Changed:
>> CXX = CC
>> To:
>> CXX = gcc
>> Changed:
>> C = cc
>> To:
>> C = gcc
>> Changed:
>> LIB = CC -xar -o
>> To:
>> LIB = gcc -xar -o
>> Then I was able to begin running a 'make' but it dies with the
>> following:
>> gcc: language ar not recognized
>> Undefined first referenced
>> symbol in file
>> cos agg_arc.o
>> sin agg_arc.o
>> acos agg_arc.o
>> ceil agg_image_filters.o
>> fmod agg_bezier_arc.o
>> main
>> /usr/local/lib/gcc/i386-pc-solaris2.10/3.4.6/crt1.o
>> sqrt agg_bezier_arc.o
>> operator new[](unsigned int) agg_bspline.o
>> atan2 agg_curves.o
>> floor ctrl/agg_polygon_ctrl.o
>> vtable for
> __cxxabiv1::__si_class_type_infoctrl/agg_cbox_ctrl.o
>> operator delete[](void*) agg_bspline.o
>> operator delete(void*) ctrl/agg_cbox_ctrl.o
>> vtable for __cxxabiv1::__class_type_infoctrl/agg_cbox_ctrl.o
>> __gxx_personality_v0 agg_arc.o
>> __cxa_pure_virtual ctrl/agg_cbox_ctrl.o
>> ld: fatal: Symbol referencing errors. No output written to
>> libagg.a
>> collect2: ld returned 1 exit status
>> make[1]: *** [all] Error 1
>> make[1]: Leaving directory `/usr/local/agg-2.4/src'
>> make: *** [src/libagg.a] Error 2
>> Thanks.
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS: 616-706-2438
>> Fax: 616-554-6484
>> From: Trent Erickson [mailto:trente at umn.edu]
>> Sent: Monday, October 15, 2007 3:32 PM
>> To: Nolte, Tim
>> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>> More technical details would be helpful. I can offer my experience
>> although it may not be applicable. I have compiled on Solaris 9 using
>> the GNU make and ld. Be sure you are using GNU ld. The Sun version
>> didn't work for me.
>> -Trent
>> Nolte, Tim wrote:
>>> I'm at the end of my rope here. I'm running up against a deadline
> and
>> I
>>> can't get AGG compiled on Solaris 10 x86 for the life of me. I'm
>> afraid
>>> I'm going to end up having to go back to GD. I made the mistake of
>> using
>>> HostGIS to setup and interim mapserver while I rebuild the existing
>> one
>>> and decided to go with Solaris as the rest of our servers are
> running
>> on
>>> it. Anyways, if anyone has successfully compiled AGG on a Solaris
> box
>> it
>>> would help me out huge! Thanks.
>>> - Tim
>>> iPCS Wireless, Inc.
>>> Kentwood, MI 49512
>>> PCS: 616-706-2438
>>> Fax: 616-554-6484
