Layer doesn't work in 5.0
Jørn Vegard Røsnes
jorn at SPACETEC.NO
Thu Oct 18 07:08:20 EDT 2007
it seems that TRANSPARENCY _must_ be larger than 0 in v5.0.
In v4.9 it works ok, e.g. my layer is visible with TRANSPARENCY=0.
cheers
Jørn Vegard
On Tuesday 16 October 2007 15:38, Jørn Vegard Røsnes wrote:
> Hi all,
> I've just tried to migrate from FWTools1.3.7 / MS 4.9 to FWTools1.3.9 / MS
> 5.0.
> The problem is that my PostGIS layer doesn't want to show up in 5.0.
> My layer conf is below.
> I've read the migration guide, but can't find the problem.
> http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/MIGRA
>TION_GUIDE.TXT
> Does anyone else see the problem?
> cheers
> Jørn Vegard
> LAYER
> NAME "layer_20071005_141040"
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=postgres dbname=db host=hostname port=5432"
> DATA "poly from feature using SRID=4326"
> TYPE point
> STATUS ON
> TRANSPARENCY 0
> DEBUG ON
> CLASS
> TEXT (oil-[oid]-[acquisition_time])
> EXPRESSION ('[timestamp]' == '20071005_141040' AND [threshold] >=
> 0 AND [threshold] < 100)
> LABEL
> FONT arial
> TYPE TRUETYPE
> SIZE 8
> MINDISTANCE 10000
> POSITION UR
> ANGLE 30
> COLOR 0 0 0
> END
> STYLE
> COLOR 224 64 0
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
