Error when create annotation layer in PHPMapscript
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue Oct 23 15:32:19 EDT 2007
Krung Saengpole wrote:
> Hi all,
> I have a question about creating annotation layer using phpmapscript. I
> created layer as follow:
> $layer=ms_newLayerObj($map);
> $layer->set("name", $name);
> $layer->set("data", $data);
> $layer->set("type", MS_LAYER_ANNOTAION);
I'm not convinced that this alone would explain the errors you got, but
there is a typo here... should be MS_LAYER_ANNOTATION... perhaps try
fixing that and see.
> when it came to
> $img=$map->draw();
> it showed 9 or 10 sentences of:
> *Warning*: [MapServer Error]: msQueryByRect(): No matching record(s)
> found. in *D:\Work\testing\area50.php* on line *40*
Could it be that you made a queryByRect() between the time the layer was
created and the time at which you call $map->draw()?
Perhaps try calling ms_ResetErrorList() after the queryByRect() or
before the call to $map->draw(). I suspect that the query leaves
warnings in the error stack and this may confuse the $map->draw() method.
Daniel
Daniel Morissette
http://www.mapgears.com/
