No subject
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Oct 25 13:21:39 EDT 2007
If you use shp2img do you see the same issue? I didn't see anything obvious in your configuration
that would cause something like this. Will try on my end too.
Steve
>>> On 10/25/2007 at 8:04 AM, in message
<E43C32BC5843E34FB4C00CDFAAAAF7D806C200 at australia.prodevelop.local>, Javier
Carrasco <jcarrasco at PRODEVELOP.ES> wrote:
> Hi everybody
> I have a problem when I try to render the shape in the shapefile annexed. If
> you look at the screenshoot I took from gvSIG, there are some segments of the
> geometry that are not displayed using MapServer but gvSIG, uDIG and arcMap
> displays correctly.
> I'm using ms4w (MapServer 5.0) and I'm getting the images using the WMS
> interface.
> This geometry is a representation of a route to deliver some packages in
> different addresses.
> it looks like two correlative segments of the path that are used to move
> from A to B and B to A are disappearing.
> Do you know if there is a bug in MapServer or am I making something wrong
> when configuring MapServer?
> Thank you
