Antwort: [UMN_MAPSERVER-USERS] Problems with SDE+Oracle
Benedikt Rothe
umn-ms at HYDROTEC.DE
Wed Oct 31 11:56:26 EDT 2007
Hi
My experience is, that following DLL's are needed:
* sde.dll
* sg.dll
* pe.dll
I copied them from the ArcSDE-SDK-directory.
I think they are also in the C:\programme\ArcGIS\bin-directory.
You should copy them in the directory od mapserv.exe or expand your
PATH-environment.
Bye
Benedikt Rothe
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
31.10.2007 16:21:43:
> Hi list,
> I'm trying to connect to SDE and Oracle (Locator). I'm using the latest
ms4w
> and followed the instructions on the Readme Install
> (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html) to
> connect to ArcSDE and Oracle. I installed both clients but nothing
works!
> If I want to show a Layer based on SDE I got following error:
> msDrawMap(): Image handling error. Failed to draw layer named 'states'.
> loadCustomLayerDLL: General error message. Failed to load dynamic Layer
LIB:
> C:/ArcGIS/ArcSDE/bin/sde.dll msGetSymbol(): General error message. Can't
> load requested dynamic library: C:/ArcGIS/ArcSDE/bin/sde.dll
> I tried several paths to link to sde.dll and also to msplugin_sde_92.dll
(as
> in the ms4w readme)
> If I want to connect to an oracle Layer, a promt offers to download
> mapserv.exe.
> Anybody an idea what I'm doing wrong??
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071031/132e7f9a/attachment.html
