QueryByRect problem in PHPmapscript
Bill Thoen
bthoen at GISNET.COM
Wed Oct 31 17:14:46 EDT 2007
I've solved part of my problem. Apparently the query function works on
the native SRS of the target layer, not on the map output SRS.
Then I've seen a reference to getFeature(), supposedly a layer method.
But this doesn't appear to be the case. In fact, I can't find references
to getFeature() in the docs; just in old emails by people. Is this a
valid method for MS 4.10?
Bill Thoen wrote:
> I'm trying to understand how to do querying via PHP mapscript, and I
> don't understand the results I'm getting. Basically I'm querying a
> polygon layer of US States with a rectangle that intersects 8 states
> in the upper midwest. It fully encloses two of these. The following
> script seems to find only one result and it says the shapeindex is 42.
> Now I know this is the answer to the meaning of life, the universe and
> everything, but how do I use this to get a list of the state names
> that were found (and why is it only returning 1 found?)
> What I want to do eventually is display these states on the map in a
> highlighting color to show they were selected. If I'm going about this
> all wrong, could somebody clue me in?
> $rect = ms_newRectObj();
> $rect->setextent(-50000, -50000, 50000, 50000);
> $lyr = $map->getLayer(1); // states layer
> $results = $lyr->queryByRect($rect);
> if ($results == MS_FAILURE) {
> echo "Nothing found.<br />";
> } else {
> echo "Found " . $lyr->getNumResults()."<br />";
> for ($i=0; $i<$lyr->getNumResults(); $i++) {
> $rcache = $lyr->getResult($i);
> echo " shapeindex: ".$rcache->shapeindex;
> $rect->free();
