QueryByRect problem in PHPmapscript
Bill Thoen
bthoen at GISNET.COM
Wed Oct 31 17:24:04 EDT 2007
I simplified it to one layer in the map, so I'm sure I'm getting the
states layer (originally I had two states layers -- polygon and line --
so that's why I used the number). And now that I'm using a rectangle in
the states native SRS (4263) I'm getting the number of states I'm
expecting. I think they're in the resultscache, and now I'm trying to
figure out how to get something useful out of that.
Steve Lime wrote:
> What does the corresponding layer definition look like? Are you sure you're grabbing the states
> layer - I mean, have you tried getLayerByName instead?
> Steve
>>>> On 10/31/2007 at 2:58 PM, in message <4728DE56.3010906 at gisnet.com>, Bill Thoen
> <bthoen at GISNET.COM> wrote:
>> I'm trying to understand how to do querying via PHP mapscript, and I
>> don't understand the results I'm getting. Basically I'm querying a
>> polygon layer of US States with a rectangle that intersects 8 states in
>> the upper midwest. It fully encloses two of these. The following script
>> seems to find only one result and it says the shapeindex is 42. Now I
>> know this is the answer to the meaning of life, the universe and
>> everything, but how do I use this to get a list of the state names that
>> were found (and why is it only returning 1 found?)
>> What I want to do eventually is display these states on the map in a
>> highlighting color to show they were selected. If I'm going about this
>> all wrong, could somebody clue me in?
>> $rect = ms_newRectObj();
>> $rect->setextent(-50000, -50000, 50000, 50000);
>> $lyr = $map->getLayer(1); // states layer
>> $results = $lyr->queryByRect($rect);
>> if ($results == MS_FAILURE) {
>> echo "Nothing found.<br />";
>> } else {
>> echo "Found " . $lyr->getNumResults()."<br />";
>> for ($i=0; $i<$lyr->getNumResults(); $i++) {
>> $rcache = $lyr->getResult($i);
>> echo " shapeindex: ".$rcache->shapeindex;
>> $rect->free();
