Oracle Spatial problem
Hunter, David - St. Louis Park, MN
David.Hunter at FNF.COM
Fri Sep 7 14:58:19 EDT 2007
I am trying to set up MapServer CGI to run in Tomcat with Oracle Spatial
support. I got the cgi-bin set up and working, and then created a test
map file and HTML template. I have test data in .TAB form and in Oracle
10g. When using the default libmap.dll from MS4W 2.2.5, the .TAB layer
displays OK, but when I add the Oracle layer it displays the
"OracleSpatial not supported" message. When I copy the libmap.dll from
cgi-bin/ignored-libmap/oracle10g to cgi-bin, a totally blank page is
displayed, no matter what layer (.TAB and/or Oracle) I use. It's as if
the template is not found or ignored. There are no messages in the log
file or anything else to diagnose the problem. Anybody have any ideas?
Here's the map file I'm playing with:
MAP
IMAGETYPE PNG24
EXTENT -79.9 40.3 -71.6 45.1
SIZE 650 520
SHAPEPATH "roadbase/"
SYMBOLSET "symbols/symbols35.sym"
FONTSET "fonts/fonts.list"
IMAGECOLOR 255 255 255
UNITS miles
WEB
IMAGEPATH "/Tomcat/webapps/ext-1.0.1/tmp/"
IMAGEURL "/ext-1.0.1/tmp/"
TEMPLATE "oratest.htm"
LOG "/Tomcat/logs/mapserver.log"
END
LAYER
NAME "Counties_Labels"
CONNECTIONTYPE ogr
CONNECTION "NYxxxxcb.tab"
STATUS DEFAULT
TYPE ANNOTATION
LABELITEM "countyname"
CLASS
LABEL
TYPE TRUETYPE
FONT arial
SIZE 10
COLOR 128 128 128
OUTLINECOLOR 255 255 255
ANTIALIAS TRUE
ANGLE auto
FORCE false
POSITION auto
OFFSET 0 0
MINDISTANCE 335
END
END
END
LAYER
NAME "Counties"
CONNECTIONTYPE ogr
STATUS DEFAULT
TYPE POLYGON
CLASS
NAME "Counties"
OUTLINECOLOR 128 128 128
SYMBOL "circle"
SIZE 3
END
END
LAYER
NAME "FireDistricts"
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION "data/fngsdata at SLP"
#DATA "GEOLOC FROM (SELECT * FROM locppc.us_1007
WHERE state = 'NY') USING VERSION 10g"
DATA "GEOLOC FROM locppc.us_1007 USING VERSION
10g"
DUMP TRUE
CLASS
STYLE
OUTLINECOLOR 0 0 0
COLOR 0 128 128
SYMBOL "circle"
SIZE 1
END
END
END
END
David S. Hunter
Sr. Software Engineer
Fidelity National Geographic Solutions
division of Fidelity National Financial
5353 Gamble Drive, Suite 201
St. Louis Park, MN 55416
Email: david.hunter at fnf.com
Phone: 952.542.1440 ext. 256
Fax: 952.542.3859
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070907/bc1c80c3/attachment.html
