Oracle Spatial problem
Fernando Simon
fsimon at UNIVALI.BR
Mon Sep 10 08:37:05 EDT 2007
Hi David,
The error: "OracleSpatial not supported" occurs whne the version of
Mapserver that you are using don't contains the connection with
OracleSpatial enabled. To fix this you have two ways, the first is use a
version with this support, and the second is compile Mapserver by yourself.
The blank image can occur because the objects from your layer was not
inside of the extent that you defined. Another issue can be with
OracleSpatial, how did you imported the data in database? Are you use
shape or library? If yes, did you execute the SDO_MIGRATE.TO_CURRENT
(you can find more info in the section 17 of the OracleSpatial manual)?
I don't recommend to use the "*" in the data definition, like "select *
from".
Best regards.
Fernando Simon
UMN Mapserver and Oracle spatial developer
Hunter, David - St. Louis Park, MN wrote:
> I am trying to set up MapServer CGI to run in Tomcat with Oracle
> Spatial support. I got the cgi-bin set up and working, and then
> created a test map file and HTML template. I have test data in .TAB
> form and in Oracle 10g. When using the default libmap.dll from MS4W
> 2.2.5, the .TAB layer displays OK, but when I add the Oracle layer it
> displays the “OracleSpatial not supported” message. When I copy the
> libmap.dll from cgi-bin/ignored-libmap/oracle10g to cgi-bin, a totally
> blank page is displayed, no matter what layer (.TAB and/or Oracle) I
> use. It’s as if the template is not found or ignored. There are no
> messages in the log file or anything else to diagnose the problem.
> Anybody have any ideas? Here’s the map file I’m playing with:
> MAP
> IMAGETYPE PNG24
> EXTENT -79.9 40.3 -71.6 45.1
> SIZE 650 520
> SHAPEPATH "roadbase/"
> SYMBOLSET "symbols/symbols35.sym"
> FONTSET "fonts/fonts.list"
> IMAGECOLOR 255 255 255
> UNITS miles
> WEB
> IMAGEPATH "/Tomcat/webapps/ext-1.0.1/tmp/"
> IMAGEURL "/ext-1.0.1/tmp/"
> TEMPLATE "oratest.htm"
> LOG "/Tomcat/logs/mapserver.log"
> END
> LAYER
> NAME "Counties_Labels"
> CONNECTIONTYPE ogr
> CONNECTION "NYxxxxcb.tab"
> STATUS DEFAULT
> TYPE ANNOTATION
> LABELITEM "countyname"
> CLASS
> LABEL
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> COLOR 128 128 128
> OUTLINECOLOR 255 255 255
> ANTIALIAS TRUE
> ANGLE auto
> FORCE false
> POSITION auto
> OFFSET 0 0
> MINDISTANCE 335
> END
> END
> END
> LAYER
> NAME "Counties"
> CONNECTIONTYPE ogr
> STATUS DEFAULT
> TYPE POLYGON
> CLASS
> NAME "Counties"
> OUTLINECOLOR 128 128 128
> SYMBOL "circle"
> SIZE 3
> END
> END
> LAYER
> NAME "FireDistricts"
> STATUS DEFAULT
> TYPE POLYGON
> CONNECTIONTYPE oraclespatial
> CONNECTION "data/fngsdata at SLP"
> #DATA "GEOLOC FROM (SELECT * FROM locppc.us_1007 WHERE state = 'NY')
> USING VERSION 10g"
> DATA "GEOLOC FROM locppc.us_1007 USING VERSION 10g"
> DUMP TRUE
> CLASS
> STYLE
> OUTLINECOLOR 0 0 0
> COLOR 0 128 128
> SYMBOL "circle"
> SIZE 1
> END
> END
> END
> END
> *David S. Hunter*
> /Sr. Software Engineer
> Fidelity National Geographic Solutions
> division of Fidelity National Financial
> 5353 Gamble Drive, Suite 201
> St. Louis Park, MN 55416
> Email: david.hunter at fnf.com <mailto:david.hunter at fnf.com>
> Phone: 952.542.1440 ext. 256
> Fax: 952.542.3859///
