Problem with long DATA object in an Oracle LAYER
Damien Corpataux damien.corpataux at CAMPTOCAMP.COM
Mon Sep 10 03:35:34 PDT 2007
Hello List,
I ran into memory corrption with a long sql query in the DATA object,
for an Oracle LAYER. It is obviously due to Mapserver memory allocation
mechanism. The corruption occurs when the DATA is longer than ca. 2037
characters.
Do you know if Mapserver has a way of modifying the possible allocated
memory limit? In header files? By applying a patch?
Any idea is welcome!
Thanks in advance, regards,
Damien Corpataux
Camptocamp SA
Damien Corpataux
PSE A
CH-1015 Lausanne
+41 21 619 10 22 (Direct)
+41 21 619 10 10 (Centrale)
+41 21 619 10 00 (Fax)
P Please consider the environment
Do you really need to print this email?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070910/b76b7bd1/attachment.htm>
More information about the MapServer-users mailing list
