Problem with long DATA object in an Oracle LAYER
Emmanuel BELO
emmanuel.belo at CAMPTOCAMP.COM
Mon Sep 10 11:23:44 EDT 2007
After some investigation, we could identify that this occurs only with
an Oracle connector. It's not reproducible with a PostGIS connection.
Here our testcase outline:
LAYER
CONNECTION "user/password at myoracleoracle9instance"
CONNECTIONTYPE ORACLESPATIAL
DATA "[Put a query larger than 2037 characters here]"
METADATA
END
NAME "oracle_test_layer"
PROJECTION
"init=epsg:4326"
END
SIZEUNITS PIXELS
STATUS ON
TOLERANCEUNITS PIXELS
TYPE POLYGON
UNITS METERS
CLASS
METADATA
END
STYLE
ANGLE 360
OUTLINECOLOR 255 0 0
END
END
END
You can build a large sql query by adding a lot of "always true"
clauses, or by padding it with a lot of spaces
eg. shape from (select shape from my_table where 'djfksdhfjkdsf' =
'djfksdhfjkdsf' and 'djfksdhfjkdsf' = 'djfksdhfjkdsf' [...])
Best regards,
Emmanuel BELO
Damien Corpataux wrote:
> Hello List,
> I ran into memory corrption with a long sql query in the DATA object,
> for an Oracle LAYER. It is obviously due to Mapserver memory allocation
> mechanism. The corruption occurs when the DATA is longer than ca. 2037
> characters.
> Do you know if Mapserver has a way of modifying the possible allocated
> memory limit? In header files? By applying a patch?
> Any idea is welcome!
> Thanks in advance, regards,
> Damien Corpataux
Camptocamp SA
Emmanuel BELO
PSE A
CH-1015 Lausanne
+41 21 619 10 25 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
