Agg and resampling
Frank Warmerdam
warmerdam at POBOX.COM
Mon Sep 10 16:30:13 EDT 2007
Rob McCulley wrote:
> Okay,
> I’ve finally had a moment to sit down and look at this again. I’m using
> the latest version of ms4w beta, which is based on beta 6. On all of my
> imagery, tiled or not, using the processing setting of
> “RESAMPLE=BILINEAR” results in the raster layer not being drawn. There
> are no error messages, and a map image is created, but the raster layer
> is not drawn. Using either “RESAMPLE=NEAREST” and “RESAMPLE=AVERAGE”
> results in the layer being drawn fine. If I switch to using GD for
> output, then “RESAMPLE=BILINEAR” works as it should, and the raster
> layer is drawn.
Rob,
I have determined this is indeed a bug in mapresample.c (checking
for _USE_AGG instead of USE_AGG) and is present in the current release
candidate (RC2).
I have created a bug report for this issue, and will apply a fix this
afternoon. Whether it makes it into MapServer 5.0 final or not depends
on whether we have enough issues to justify another RC go-around.
http://trac.osgeo.org/mapserver/ticket/2303
Thanks for the specific report - it made it very easy for me to find the
problem.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
