Antwort: Re: [UMN_MAPSERVER-USERS] Problem with long DATA object
in an Oracle LAYER
Benedikt Rothe
umn-ms at HYDROTEC.DE
Tue Sep 11 03:41:31 EDT 2007
Hi Emmanuell
If your project is stuck with this problem: In cases like this, I always
try to avoid long SQL-statements in mapfiles
anyway. Instead I put the complexity in a view and use in the mapfile
just this view.
Benedikt Rothe
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
10.09.2007 18:28:00:
> Hi Fernando,
> thank you for investigating. We need this for a project, where it is not
> possible to use PostGIS.
> Do you have an idea how long it would take to fix the problem? Can we
> help you in some manner?
> Best regards,
> Emmanuel
> Fernando Simon wrote:
> > Hi all,
> > I will investigate the problem. I believe that it's relate with the
> > msSplitData function in the driver source code.
> > Thanks for the reply about the error.
> > Best regards.
> > Fernando Simon
> > UMN Mapserver and Oracle Spatial developer
> > Emmanuel BELO wrote:
> >> After some investigation, we could identify that this occurs only
with
> >> an Oracle connector. It's not reproducible with a PostGIS connection.
> >> Here our testcase outline:
> >> LAYER
> >> CONNECTION "user/password at myoracleoracle9instance"
> >> CONNECTIONTYPE ORACLESPATIAL
> >> DATA "[Put a query larger than 2037 characters here]"
> >> METADATA
> >> END
> >> NAME "oracle_test_layer"
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> SIZEUNITS PIXELS
> >> STATUS ON
> >> TOLERANCEUNITS PIXELS
> >> TYPE POLYGON
> >> UNITS METERS
> >> CLASS
> >> METADATA
> >> END
> >> STYLE
> >> ANGLE 360
> >> OUTLINECOLOR 255 0 0
> >> END
> >> END
> >> END
> >> You can build a large sql query by adding a lot of "always true"
> >> clauses, or by padding it with a lot of spaces
> >> eg. shape from (select shape from my_table where 'djfksdhfjkdsf' =
> >> 'djfksdhfjkdsf' and 'djfksdhfjkdsf' = 'djfksdhfjkdsf' [...])
> >> Best regards,
> >> Emmanuel BELO
> >> Damien Corpataux wrote:
> >>> Hello List,
> >>> I ran into memory corrption with a long sql query in the DATA
object,
> >>> for an Oracle LAYER. It is obviously due to Mapserver memory
allocation
> >>> mechanism. The corruption occurs when the DATA is longer than ca.
2037
> >>> characters.
> >>> Do you know if Mapserver has a way of modifying the possible
allocated
> >>> memory limit? In header files? By applying a patch?
> >>> Any idea is welcome!
> >>> Thanks in advance, regards,
> >>> Damien Corpataux
> Camptocamp SA
> Emmanuel BELO
> PSE A
> CH-1015 Lausanne
> +41 21 619 10 25 (direct)
> +41 21 619 10 10 (centrale)
> +41 21 619 10 00 (fax)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070911/c2edc00a/attachment.html
