MapScripting on ASP pages
Marcos Sánchez Provencio
marcos at BURKE.ATH.CX
Wed Sep 12 04:53:24 EDT 2007
You might try to build an ActiveX with the Python Windows extensions,
although it might have a performance hit (probably trivial compared to
the map processing, probably not).
El mar, 11-09-2007 a las 21:18 -0500, Howard Butler escribió:
> Do you mean old-school VB6? no. You could use the .NET/C# bindings
> with ASP.NET though.
> Howard
> On Sep 11, 2007, at 8:42 PM, Hayden Fisher wrote:
> > Hi All,
> > Have basically just started with MapServer, MapScript etc. My
> > situation is that I’d like to build a mapping application into some
> > ASP pages, e.g. VB.
> > However the examples I’ve come across are all for either PERL,
> > PYTHON and PHP.
> > (These existing pages are already querying out a lot of attribute
> > information from MapInfo tables so there’s not too much chance of
> > changing languages, hence the following questions)
> > Is there a VB version out there? If so where could I find a copy?
> > If not is there still a way to build an application into the *.asp
> > pages using the above languages?
> > Any advice would be great on where to start.
> > Regards,
> > Hayden Fisher
> > Development and Support
> > BizeAsset Pty Ltd
> > support at bizeasset.com.au
> > Mob: (04) 3838 4747
> > Ph: (07) 3369 2222
> > Fax: (07) 3369 8883
> > Toll Free: 1800 836 850
