Win32 Compilation and Installation
Hayden Fisher
support at BIZEASSET.COM.AU
Wed Sep 12 22:58:26 EDT 2007
Hi Howard,
I'm using MS Visual Studio .Net 2003 that should do the trick, yes? And
will be .Net 1.1 compatible?
And what if I eventually want to go to .Net 2.0? I'd need Visual Studio
2005 with what buildkit?
Regards,
Hayden Fisher
Development and Support
BizeAsset Pty Ltd
support at bizeasset.com.au
Mob: (04) 3838 4747
Ph: (07) 3369 2222
Fax: (07) 3369 8883
Toll Free: 1800 836 850
-----Original Message-----
Sent: Thursday, 13 September 2007 12:44 PM
To: Hayden Fisher
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: Win32 Compilation and Installation
MS4W provides C# bindings for MapServer, and unless you are looking
for something very specific, it is likely to cover most/all of your
needs.
Alternatively, I would suggest getting a copy of the latest MapServer
buildkit <http://download.osgeo.org/buildkit/>. Note that this is
only compatible with MSVC 2003, not 2005. It has everything pre-
configured/setup if you can use 2003.
I admit the Win32 Compilation doc has been neglected some since most
of us started just using the buildkit as our base. If you must still
soldier on, please add comments to the bottom of the doc with updates
that need to be made and we will try to incorporate them in the next
iteration of the doc (don't know when that would be).
Howard
On Sep 12, 2007, at 9:27 PM, Hayden Fisher wrote:
> Hi All,
> Attempting to compile MapServer and then MapScript for C#. And have
> been trying to follow the 'Win32 Compilation and Installation'
> tutorial.
> The link to regex is not current, does anyone know if this is still
> necessary? Or have a more up to date instruction manual for
> building MapServer?
> The version I'm trying to compile is 4.10.2
> Regards,
> Hayden Fisher
> BizeAsset Pty Ltd
> Mob: (04) 3838 4747
> Ph: (07) 3369 2222
> Fax: (07) 3369 8883
