Labelangleitem question
Stéphane RIFF
stephane.riff at CERENE.FR
Thu Sep 13 10:31:00 EDT 2007
First, Thanks for answer.
I found another way to do this that is not explain in the documentation.
We can set the labelangleitem with mapscript to :
$layer->set("labelangleitem","(angle*-1)");
This works for me. So maybe it can be part of the documentation ?
Does the subquery method is still using the indexes of the table (I
don't think so) ?
Thanks
Steff
thomas bonfort wrote:
>you can use a custom query on your database
>DATA "the_geom from
> (SELECT gid, nom, the_geom, (-angle) AS inv_angle FROM troncon_route)
> as foo using unique gid"
>and then use
>ANGLE [inv_angle] in your label block
>tb
>On 9/13/07, Stéphane RIFF <stephane.riff at cerene.fr> wrote:
>>Hello,
>>I want to invert the sign of the field I want to use in
>>layer->labelangleitem.
>>I don't want to it in the database because the information are sent by gps.
>>I want to know if it's possible do it on the fly with mapscript and how
>>(expression in the labelangleitem property ???) ?
>>Thanks
>>Steff
