FastCGI , ArcSDE, mapserver testing performance
Ruben Pardo
correosig at GMAIL.COM
Thu Sep 13 12:52:32 EDT 2007
Hi everybody,
I installed mapserver, with arcsde, fastcgi, without compilation problems
(i think that is correctly working), but i have not seen better performance
in my test.
I'm testing with jmeter (around 300 request) with fastcgi enabled and
disabled (commenting code in httpd.conf), and the performance are similar.
I have no logs in
what am i doing incorrectly?
This is my configuration:
My linux distro is :
Linux version 2.6.15-1.2054_FC5smp (bhcompile at hs20-bc1-3.build.redhat.com)
(gcc version 4.1.0 20060304 (Red Hat 4.1.0-3))
the output for ./mapserv -v is :
MapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP OUTPUT=SVG
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=SDE INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG
a ps -axf output with apache and mapserver running is ::::
19785 ? Ss 0:00 /usr/local/apache/bin/httpd -k start
31651 ? S 0:00 \_ /usr/local/apache/bin/fcgi- -k start
31652 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
31653 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
31654 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
31655 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
31656 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
31660 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
31663 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
31664 ? S 0:00 \_ /usr/local/apache/bin/httpd -k start
the httpd.conf snippet code is
LoadModule fastcgi_module /usr/local/apache/modules/mod_fastcgi.so (and
having mod_fastcgi.so in this place)
AddHandler fastcgi-script fcgi
FastCgiConfig -appConnTimeout 200 -idle-timeout 60 -init-start-delay 1
-minProcesses 4 -maxProcesses 20 -maxClassProcesses 20
thanks very much.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070913/3c3cdc59/attachment.html
