Odd query results on Point layer
Van Ulden, Joost
jvanulde at NRCAN.GC.CA
Thu Sep 13 15:40:04 EDT 2007
Actually we are having the same problem here. What version are you
using?
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Lawrence Hartpence
Sent: September 13, 2007 07:36
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Odd query results on Point layer
Hello,
I have a point layer which is actually a database with X & Y fields.
When I perform use query mode and select points, the results I get don't
match the point I am selecting. Could someone help me understand what I
am doing wrong?
Lawrence
http://gismap/JasperMaps/cgi-bin/mapserv.exe?&program=%2FJasperMaps%2Fcg
i-bin%2Fmapserv.exe&map=C%3A%5CInetpub%5Cwwwroot%5Cmapdocs%5CSeptic.map&
zoomsize=2&layers=ortho+Septic+Parcels+Lots+ROW+Survey+Section+Sub+Parce
lPt+Water+Shields+Highways+Roads+Watershed+County+Towns&mode=browse&slay
er=Parcels&imgxy=320+240&imgext=1680507.39+547052.00+1844030.00+680312.5
1&mapshape=&imgshape=&imgbox=&qstring=&qlayer=Parcels&qitem=&shapeindex=
&savequery=
Here is the point layer in my MAP file:
LAYER
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='Septic'>
<SrcDataSource>ODBC:@Septic</SrcDataSource>
<SrcLayer>tblSewersyAllHistoricInfo</SrcLayer>
<GeometryField encoding='PointFromColumns' x='X' y='Y'/>
<GeometryType>wkbPoint</GeometryType>
</OGRVRTLayer>
</OGRVRTDataSource>"
CONNECTIONTYPE OGR
DATA "Septic"
#METADATA
# "wms_srs" "4326"
# "wms_title" "Septic"
#END
NAME "Septic"
DUMP TRUE
TEMPLATE 'C:\MS4W\Apache\htdocs\Septic\Septic_query.html'
HEADER 'C:\MS4W\Apache\htdocs\Septic\Septic_head.html'
TRANSPARENCY 100
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 7
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS FEET
LABELITEM 'septicpermitnumber'
CLASS
STYLE
COLOR 170 0 170
MAXSIZE 100
MINSIZE 1
SIZE 6
SYMBOL "square"
END
LABEL
TYPE TRUETYPE
SIZE 10
FONT Arial
COLOR 170 0 150
OUTLINECOLOR 255 255 255
POSITION UC
#ANGLE AUTO
OFFSET 0 5
MINDISTANCE 200
END #LABEL
END
END
