KMLMapServer project beta release
Alessandro Pasotti
ale.pas at TISCALI.IT
Fri Sep 14 04:34:17 EDT 2007
Hello,
I released the first beta of a small package the helps serving mapserver data
as KML/KMZ folders and/or network links.
It is written in php_mapscript and use PHP5 with simplexml functions.
Licence is GPL but commercial support/licencing is available on demand.
The goal of this project is to add KML output capabilities to any running
MapServer installation. It will run out-of-the-box with zero or minimal
configuration. Basically you just install this package somewhere under you
web server root and it will work without any configuration. Configuration, if
needed, is done through metadata in the MapServer’s mapfile, so you don’t
have any other configuration files to worry about.
There is also a simple caching system since some requests could be quite CPU
intensive.
By now, the project page and download is here:
http://www.itopen.it/soluzioni/kml-map-server/
Testers, bug hunters and help are welcome!
Alessandro Pasotti
itOpen - "Open Solutions for the Net Age"
w3: www.itopen.it
Linux User# 167502
