flash swf polygon highlight
Shannon Scott
sscott at LOCATIONINC.COM
Mon Sep 24 11:21:51 EDT 2007
Hello,
I have a flash map. I have built an application so that when the person
mouses over the map - the highlighted polygon ( under mouse ) will
highlight part of the web page - with corresponding information. I
would like to also make it so when the web page is moused over the
respective polygon will also become highlighted.
I am able to access the polygon attributes through the Element array.
Is there a way to highlight the polygon using actionscript - if I know
the Element array index number?
Any help or pointers are appreciated.
Thank you.
Shannon
