[mapserver-users] Unable to access Grid Object (GridObject) via
C# MapScript interface (related to bug 1980)
Tamas Szekeres
szekerest at gmail.com
Wed Apr 2 12:52:40 EDT 2008
Brian,
Which version are you using? I guess the mapserver 5.0 should contain
this option. Here's the related change, which is pretty old.
http://trac.osgeo.org/mapserver/changeset/6362
Best regards,
Tamas
2008/4/2, Hulbert, Brian <brian.hulbert at linquest.com>:
> Tamas,
> Thanks for the suggestion but the layerObj does not contain and
> UpdateFromString property or method (when viewed from Visual Studio's object
> browser nor when viewing the API reference online). Thoughts?
> Brian
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
> Sent: Tuesday, April 01, 2008 4:48 PM
> To: Hulbert, Brian
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Unable to access Grid Object (GridObject) via
> You can probably use layerObj.UpdateFromString with the string you
> have in your mapfile. However I'm not sure how you loose your settings
> after the first refresh? Do you recreate your map by using Clone() or
> something?
> We should also fix msCopyLayer to copy the layerinfo with the graticule
> layers.
> Best regards,
> Tamas
> 2008/4/1, Hulbert, Brian <brian.hulbert at linquest.com>:
> > I have a MAP file that contains a layer for displaying graticule (see
> > below). However, after the first refresh, the labelformat for my grid
> > object is lost. This was noted in bug 1980. I cannot find a workaround
> for
> > this bug by traversing the layer->class object hierarchy and trying to set
> a
> > labelformat for the GridObject.
> > Can the label format be reset via the mapscript_csharp dll interface? If
> > not, is drawing the graticule lines better accomplished via a shape file?
> > Even if I need to do both a equirectangular and orthographic projections?
> > Ref: I am using MapScript 5.0.2 and calling it from C# using MS VS 2005
> > LAYER
> > NAME "grid"
> > METADATA
> > "DESCRIPTION" "Grid"
> > END
> > TYPE LINE
> > STATUS ON
> > PROJECTION
> > 'proj=longlat'
> > 'ellps=WGS84'
> > 'datum=WGS84'
> > 'no_defs'
> > END
> > CLASS
> > NAME "Graticule"
> > COLOR 192 192 192
> > LABEL
> > COLOR 255 255 0
> > FONT arial
> > TYPE truetype
> > SIZE 8
> > POSITION AUTO #ur
> > PARTIALS FALSE
> > BUFFER 5
> > END
> > END
> > GRID
> > LABELFORMAT "%g°" # dec degrees with symbol
> > MAXARCS 10
> > MAXINTERVAL 10
> > MAXSUBDIVIDE 64
> > END
> > END # Layer
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
